randocommando
i have a 1980 W150 with the 5.2 does the ground wire of the coil need to have a special resistor or can i just straight ground it I'm not getting any spark I've replaced pretty much everything when i turn the motor over the coil is getting warm only after a few turns i do have it hooked to the blast resistor i just replaced the coil too any help would be great thanks
