Nwa-ram
- Oct 9, 2012
- 14
- 0
- 1989
- 5.9l Cummins
Posted once thought I had the issue corrected.... I was wrong.
Review of the problem. Windows and HVAC dont work. If you hit the window button or turn on the hvac nothing works but the center console lights "wait to start" "water in fuel" will light up.
Today I tried a couple tests.... I took out both fuses and tested each one at a time, same scenario. So next test, I found the hot side of the cigarette lighter fuse holder. Hooked it into what should be the non hot side of the of the window block and then hvac trying both. They work! The center console lights dont come on!
So next test, take the hot side of the fuse block for the windows and hvac and using a length of wire brushed a ground and no spark, but the center console lights came on!? I cant even figure out where the hell those lights are even connected to the hvac / windows.
So not sure what is going on, I would assume the power feeding the hvac and windows has a bad ground, and its energizing something else, I dont know I am so lost. Any ideas??
Sent from my SM-P600 using Tapatalk
