radio change
oldblue
d250
my truck did not have a radio when i bought it and id like to install one that i can atleast play cd's. i dont need a "bumping sound system" simipler the better. im looking for a cheap after market one or one that could be swapped form a different vehicle
88rambigblock
wv
1970 coded 440 big block
Does it have the wiring for a stereo? If it does you can get an adapter at wal mart and a dash install kit at wall mart. Youd have to install speakers. I have no idea what to do if it dpesnt have the wiring.I'm not a stereo guy.
O
oldblue
d250
im pretty sure it does. the wires are a bit of a mess. it doesnt look like there are to many wires so i can probably figure it out. it looks like there is speakers in the side of the doors. i may just through in a stock radio for now if i can find one
cumminswisher44
Pennsylvania
Any aftermarket radio can be put in these old trucks easily. Couple wires. Costant power (for the clock) ground, power when the key is in run position, depending on speakers two or 4 wires for audio. And your antenna wire. Installed a phase linear in my 82 with 4 stock speakers. Took about half hour.
midcities
i installed this pioneer in my 91 d150 and was very easy
