What does this pink wire connect to?
Jim G
Hey folks. Looking for some help. I have been enlisted to help my sons girlfriend get her 83' truck running. It has a v-8 with what I think is a 360. There is a pink wire coming out of the wiring loom on the drivers side near the firewall and not connected to anything. The wire is about 18-24 inches in length and has about 1/2" of exposed copper sticking out of the end. When we connect this wire to 12v you can hear the distributor clicking and the truck will start and run. I know this wire should be connected to a switched power source but for the life of me I can't figure out what it should be tied into. Can someone please tell me what to connect this thing to. Better yet if you have a pic that shows how and where it ties into that would be great. Thanks
crazzywolfie
under the truck
sounds like it might be the wire that is suppose to plug into the ballast resister. without it connected the coil gets no power
cgeorgemo
Joplin, MO
3.6 Pentastar
If its like my old Dart there was a white resistor on the firewall that I used to jump with a screwdriver because it went bad.
