KevenP
- Oct 29, 2015
- 1
- 0
- 1990
- 360 Gasser
I'm looking for some help folks.
1990 D150 with a 1968 383.
I've installed a Chrysler electronic ignition system on it, but it won't run.
Fires during cranking, but when I release the key, it dies.
New distributor, coil, ECU, ballast resistor, wires, plugs,ect.....
I have a separate wire running from the starter solenoid up to the ballast resistor and another with 12 volts to the other side (two post ballast resistor).
The truck is throwing a 42 code. Could it not be happy with the factory distributor unplugged? (Automatic shutdown relay circuit open or shorted)
Any help would be GREATLY appreciated.
