Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Engine & Performance
5.7 Swap into D150 Completed
This is a discussion on 5.7 Swap into D150 Completed within the Engine & Performance forums, part of the 1st Gen : 1981 - 1993 category!
That's a nice looking truck, and now it'll run like a beast too. I'd love to have a project truck ...
Like Tree16Likes
Sponsored By: Moe's Performance
Reply
Old 11-07-2016, 07:57 PM   #11 (permalink)
Mega-Hemi's Avatar
Ram Year: 2013
Engine: Cummins 6.7
Default
That's a nice looking truck, and now it'll run like a beast too. I'd love to have a project truck like that.
Sponsored Ad
Register to remove this ad.
__________________
2013 2500 Crew Cab CTD 4x4
Mega-Hemi is offline   Reply With Quote
Old 11-08-2016, 03:26 PM   #12 (permalink)
fasthemiram12's Avatar
Ram Year: 2012
Engine: Eagle 5.7 vvt
Default
Got the same project in the works...
What motor mounts were used?
__________________
Had 2011 Express [email protected]
http://www.youtube.com/watch?v=BA_UAWbGYZE
Had 2012 Express SRT Jeep Headers, TruTac & 4.10's
Now 2016 8sp QCSB
fasthemiram12 is offline   Reply With Quote
Old 11-08-2016, 04:53 PM   #13 (permalink)
Ram Year: 1984
Engine: 5.7L Hemi
Default
The mechanic fabricated mounts using a combo of the old 318 mounts and the new 5.7 mounts
Yoox_II is offline   Reply With Quote
Old 11-08-2016, 08:34 PM   #14 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
What did you end up using for the gas tank and fuel pump?
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Old 11-08-2016, 08:48 PM   #15 (permalink)
Ram Year: 1984
Engine: 5.7L Hemi
Default
Using the stock gas tank but retrofitted a 2012 ram fuel pump. I gas gauge isn't working as of yet. I found some semi brake lines that are rated for 138psi and a hemi needs 57psi, plus they were 10x cheaper than buying actual fuel lines
Old 11-08-2016, 10:54 PM   #16 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
you could have got rubber fuel line fairly cheap. i am pretty sure even the "low pressure" fuel line is rated for 60 psi or something like that. i know the guys at my local store have mixed it up a few times when i tell them i want fuel line. it is for a fuel injected vehicle but i don't need something rated for 70-80psi. you could have also got steel fuel line. the stuff is cheap but pretty hard to bend.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 11-09-2016, 04:11 PM   #17 (permalink)
usaf2006's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
I'm sure I'm not the only one who would love to see a video walk around and start up!
__________________
2006 1500 RCSB 5.7, 4wd, Paid Off Build Thread
Cosmetic
Debadged Tailgate, New Carpet
Performance
Airaid MIT, SC 87 tune, LT285/70/17 Cooper ATPs
usaf2006 is online now   Reply With Quote
Old 11-09-2016, 05:20 PM   #18 (permalink)
Ram Year: 1984
Engine: 5.7L Hemi
Default
Good points crazzywolfie, I was in a bit of a time crunch with finding parts so I jumped on the semi brake lines when I found them for so cheap. The some steal lines would have been nicer looking for sure. I will post a link to a walk around once I make one hopefully this weekend. Maybe try a 0-60 video as well.
Question, a G3 hemi is rated at like 398HP. Obviously it's a little lower since it's not brand new, maybe 375? Anyway, is there any reason I WONT be able to notice a power difference? Will my old 727 transmission restrict the hemi's power? Also, the engine seems to rev very low when in gear, so I might need to get a different rear end to wake it up a bit
Old 11-09-2016, 06:58 PM   #19 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
you should notice a big difference. the 727 won't restrict the power but it is not as efficient as newer transmissions. that brings up the next point. you may want to save for a transmission swap or rebuild because that newly gained power will likely cause the transmission to fail especially if you are driving it like a race truck. i wouldn't touch the gears in the rear. they are pretty much matched to work with the gears in the transmission. you don't want the engine to be reving high at highway speed. if it shift at a lower rpm with your foot to the floor then you probably need to keep adjusting the kick down linkage. it effects when and were it shifts or kicks down. i know i got the one on my 89 adjusted so that you barely notice 2nd gear is gone
__________________
Old 11-09-2016, 07:21 PM   #20 (permalink)
usaf2006's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Well gen ii hemis are supposedly 345 hp, but most stock motors dyno around 260. I'm guessing you're in the mid 300s.
__________________
Cosmetic
Performance
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A couple jobs completed!! Tsbot Exterior 11 10-08-2015 03:19 PM
Completed a few Mods in the last few weeks redskinredtaco General Discussions 7 09-04-2015 01:51 PM
Some projects completed G8rDuc General Discussions 4 11-14-2014 07:15 AM
1985 Dodge Ram D150 Frame Swap Questions Help!!??............ 85Dodge360-4BBL General Discussions 0 08-22-2014 10:23 AM
Phase One completed! Dante221 Lifted 16 05-22-2014 11:32 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
