Hi I have a 1988 w100 5.2 magnum 4 barrel 4 speed manual transmission truck and the 5.2 is wore completely out smokes bad and no power and I have a 98 5.9 magnum with 60k on it I know I have to use the magnum flywheel but what clutch to use is the problem mine is 23 spline and magnum is 10 spline will the 88 pressure plate fit the magnum flywheel sorry for the paragraph new to the forum
