Marksman
- Nov 14, 2014
- 78
- 10
- Texas
- 1999 Ram 2500 4x4 SLT
- V10
Hey everyone, first post. I've got a 84 w150 with a 25 sec 0-60 273 out of a 67 dart....
I will either build a 318 or a 360 for it (obviously). My goals are to be able to pull a trailer and be able to at lease break my tire loose.
Here's it's story. Bought it in 2011 with 99k miles on it and had a 360. It ran pretty good but needed valve seals (smoked some on startup) and had 4 rubber freeze plugs in it. 5 miles after it turned 100k the rear main seal let loose and it poured 4 quarts of oil on my driveway while I was tuning the carb.
Yanked it out and put the 318 out of my 76 d200 pasture truck. It was rebuilt and had 25k miles on it. It ran like a scalded ape for a 318 ( was under 10 seconds 0-60 which I felt was pretty good for an 80s 4x4 with 3.23 gears) after 5k miles or so it started smoking pretty good ( crappy 2 barrel carb that was on it in the 76 wiped the rings out). Pulled it and put a 2000 mile 273 out of a 67 dart just so I could drive it while building one of the others. Runs great and sounds good while it's wound up but it is an absolute pig. Tops out at 75 or so and can't pull a hill without losing 20 mph and me having to pull it down into 2nd.
I want to get 300 or so HP out of the 318 and 350 out of the 360 with as much torque as possible. I want it to not be a pig and pull a trailer if I need it to.
Which do yall think I should build? Both engines still have home marks in them so neither need boring. I am really leaning towards the 360 because they are torquier to begin with and would produce power easier in my mind.
If any of you have done anything like this and would share your build I would appreciate it.
Main thing I need to know is what cam would be ideal. It's a 727 With 3.23 gears. Another are what heads should I use? I have a chance at a set of 3418915 71-72 340-360 j heads.
Thanks everyone.
Thanks everyone.
