Blue Meanie
- Aug 21, 2012
- 12
- 0
- 1986
- 318
Hi all,
I've owned this truck for about 8 years, and around six years ago, I tore down the 318 to the long block to refresh it (estimated 140,*** on the motor at the time, half a million on the truck). While doing that job, I cleaned out the intake manifold, rebuilt the 2bbl, checked the heads for leakage, checked the cam lobes, cylinder walls, pulled the oil pan, checked the big end bearings, pulled out the non functioning compressor/condenser, ripped out the smog, welded up the stock exhaust manifolds, did the timing chain, bypassed the brain box in favor of 70's electronic ignition, (carb is 70's vintage Carter BBD), went to a 180 thermostat instead of 195, did plugs, wires, and all the rest.. I've gone from this being my DD to one of six cars in my fleet.. I've probably only put about 20,000 on it since.
So, here's the problem.. At highway cruising speeds, (65 MPH, 727 TF, 3.23 Sure Grip rear) this thing pings constantly.. It probably has for a while, but with an empty cat, and a glas-pack, the noise drowned it out until I heard it next to a jersey barrier. When towing, or under heavy accelerating load, it can shut off momentarily.. no popping, pinging, or drama, it just stops working until I let off of the gas, and feather the throttle back in.. The vacuum system is sealed as far as I can tell... I figured the ethanol was lowering the boiling point of the gas going to my mechanical pump, so I re-routed the line in front of the electric fan, and the radiator, changed the fuel pump (mechanical, Chinese electric versions are doo-doo squirt), and the problem persists. As for the pinging, I assumed a vacuum leak, or the vacuum and/or mechanical advances were too aggressive at around 3-4000 RPM under light to medium load.. Dizzy is set to around 10 BTDC, vacuum advance is disconnected (helped a little).
All that rambling brings me to this: I'm thinking of switching to a 4bbl setup anyway, likely an Edelbrock 650 carb/manifold combo because I've got it laying around.. I plan on leaving the cam stock, because I have six other cars that need work, and a cam isn't in this truck's budget. Assuming I stay stock, what mechanical/vacuum advance do you guys run/recommend? Should I go to the 4bbl, what ideal dizzy/carb/jet combo should I look at assuming a stock cam profile? I ran the 650 on my '68 Satellite for years in the same config with decent power/fuel ratios...
And the damned shutoff problem.. I still swear by vaporlock, it only happens in summer, usually in traffic, or while hauling/towing.. My hope was that the aluminum carb and manifold would help the whole thing run cooler.. I've also since learned about the delta-T effect, and might put the 195 T-stat back in..
Sorry for the length, I figured I'd waste everybody's time up front instead of forty replies asking me for running conditions, settings, etc..
Anyone make it to the end, and have any ideas?
Matt
Matt
