[email protected]
truck is a 3.9l v6. Ran fine up until a week ago. Noticed some bogging down when leaving from a stop. I thought it would be a good idea to try a msd coil. This did not help. The problem got worse. I also noticed the coil arcing out. I have no idea what that's about. so Back on with the old coil. The problem started getting worse. So went through the motions. Replaced, air filter, spark plugs, fuel filter, cap and rotor. still no luck. Sprayed and cleaned throttle body. now its a pain the a$$ to start. have to hold the key for a min before it starts. Idles fine ... revs fine... but in gear its stumbling bad with any sharp acceleration. I can get steady driving but that's it. I thought fuel injectors but when I was cleaning the throttle body I can see them spraying and I figured the problem would be at idle and in park also. Any thoughts would be appreciated.
