Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Engine & Performance
89 ram with issues
This is a discussion on 89 ram with issues within the Engine & Performance forums, part of the 1st Gen : 1981 - 1993 category!
Does this truck have a ballast resistor?...
Like Tree1Likes
Sponsored By: Moe's Performance
Reply
Old 11-01-2016, 10:52 PM   #11 (permalink)
Ram Year: 1989
Engine: 318
Default
Sponsored Ad
Register to remove this ad.
robsnyder225 is offline   Reply With Quote
Old 11-02-2016, 06:36 AM   #12 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
no it shouldn't. that should be built into the coil on your truck.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 11-02-2016, 07:54 AM   #13 (permalink)
Ram Year: 1989
Engine: 318
Default
That's what I was thinking too. I was told that the pickup coil could cause this issue too. Guess its time to just tear into the wiring and chase
Old 11-02-2016, 08:03 AM   #14 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i wouldn't tear into the wiring just yet. does it have that relay on the drivers side fender? if so i would be testing the wires to it for power. you could also pull codes to see if there is anything that the computer is complaining about.
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
45 Overdrive solenoid shorted or open (automatic transmission only)
46 Charging system voltage too high
47 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
weeseven likes this.
__________________
Old 11-03-2016, 04:26 PM   #15 (permalink)
Ram Year: 1989
Engine: 318
Default
Thank you. I'll have to try this out to. I already know the wires to the coil need fixed. And I'm pretty sure that there are some relays missing from the inner fender. Just gotta start somewhere. I'll give an update after this weekend.
Old 11-03-2016, 07:42 PM   #16 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
You can test the wire to the coil. You just need to find that relay before you can really test much farther
__________________
Old 11-07-2016, 04:04 PM   #17 (permalink)
Ram Year: 1989
Engine: 318
Default
It didn't give any codes except the 55. Found all the relays and fixed a bunch of wires that looked like a rats nest. Got the fuel pump to work with the key and got power to the coil. Have power out of the coil but no spark from the distributor. Should this year truck have a reluctor in the distributor? Because it doesn't have one and I'm baffled, if its not the pickup coil then what could it be?
Old 11-07-2016, 04:26 PM   #18 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
so the fuel pump kicks on for a few seconds and then shuts off when you first turn the key on? do you also hear the throttle kicker on the throttle body making noise when you turn the key on?
your truck would not have a reluctor. they have a hall effect setup.
__________________
Old 11-07-2016, 09:53 PM   #19 (permalink)
Ram Year: 1989
Engine: 318
Default
The fuel pump kicks on and back off. The throttle kicker is also working like it should I believe. It makes noise when the key first turns on and then does it again when shut off. So now I believe its a spark issue and it may be the pickup coil. Just gotta find out how to test it and how to change it if its bad.
Old 11-07-2016, 10:11 PM   #20 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
the hall effect sensor in the distributor is easy to change. there is only 2 screws holding the hall effect sensor in the distributor and i think you can remove it with the distributor in in the engine. i don't now if there is a way to test the sensor.
have you checked to see if you are getting spark right from the coil?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GPS issues KevTN Audio & Electronics 0 04-30-2016 05:19 PM
HID Issues lone12star Audio & Electronics 0 05-10-2014 03:06 AM
hid issues harr118 Exterior 12 07-15-2012 10:27 PM
Newbie Here. 5.9 V8 issues, pinging sounds, power issues, drivetrain clunking an more 2000DirtyDodge Engine & Performance 7 02-15-2012 09:27 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
