Firstly, hello everyone. I am new to the forums and this is my first dodge. I got this truck at a good price ($400) with a clean title and just couldnt pass up the deal. Its got a 318 fuel injected mpfi. It was not running, and was told had an ignition system problem. It had a new crank sensor, and what looks like two used coils. I tried both and found that one was bad. I replaced the pickup coil and repaired some frayed or broken wires i found and it fired up, but ran terrible.
I thought it was timing, so i brought it up to tdc and comfirmed the timing mark on the HB then set the rotor to #1.
Still ran terrible. Backfiring through exhaust and seems to be missing on several, with no power. I checked the cap and rotor which both look new. Replaced the wires and cleaned the plugs which looked carbon fouled (dry, black soot).
I checked the voltages at the pickup coil, tps, map which are all within spec. The map was 4.5v not running and flucuates from 2.5-2.7 when running.
I dropped the tank to check for trash, and was good. Replaced the fuel filter.
It will start right up every time, and sometimes just feels like a misfire on multiple cylinders, and sometimes will backfire through the exhaust. If you give it any gas at all it will backfire through exhaust.
At the moment i dont have the money to throw at it until next paycheck, and im mainly fiddling with it while im off this week. But would really like some input, as it is driving me crazy.
Thanks ahead of time for any assistance, and im sorry about the long post.
John
John
