Powerddge1138
- Jul 12, 2014
- 16
- 0
- 1990
- 360 5.9
Ive been working on this truck for over a year and I am about to just take it to a junk yard!
Problem: It lobes when it is cold and you have to keep on the gas to keep it running, but when it is warm, it runs and idles just fine. This all started after I did an oil change and I put rotella 10w-30 in it, Yes I know that is diesel oil. But ive heard of guys using the 10w-30 in gas engines. And yes Ive done multiple oil changes (with new filters) after, always when the motor is hot so the oil is thinner.
Parts Changed:
Fuel injectors Twice. (TBI)
Intake manifold and gaskets.
Spark plugs and wires.
Cap, Rotor and coil.
Idle Air control Actuator
Coolant Temp Sensor
Radiator
Air filter and housing
Compression Tested, all cylinders at 140 or above.
Vacuum test at 19 inch of mercury.
Coolant changed and no air in the system.
Fuel Filter was changed Earlier this year.
Ive adjusted the idle the way the chiltons manual and the way some guys on here have told me too and that hasnt helped either. I can't think of anything else. At the risk of sounding rude DO NOT RESPOND, IF YOU HAVEN'T READ THE ENTIRE POST.
Please help!!
Parts Changed:
Coolant Temp Sensor
Radiator
Please help!!
