Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Engine & Performance
Battery not charging
This is a discussion on Battery not charging within the Engine & Performance forums, part of the 1st Gen : 1981 - 1993 category!
So I was having some problems with my truck. It started off as an engine surge went from 0-1000 rpm ...
Sponsored By: Moe's Performance
Reply
Old 10-19-2016, 02:21 PM   #1 (permalink)
pnajera01's Avatar
Ram Year: 1988
Engine: 3.9 LA
Default Battery not charging
So I was having some problems with my truck. It started off as an engine surge went from 0-1000 rpm then shut off. i took the battery in to Oreillys and they said it was bad so i bought a new battery, everything ran great for a few days then the truck just died and wasnt cranking anymore. i took the battery back in and had it charged up then i had them test my alternator they said that was bad too. i bought a new alternator and guess what it happened yet again a couple days later. The batt is only receiving 12.4 volts when on. Could it be the voltage regulator gone bad?
Sponsored Ad
Register to remove this ad.
pnajera01 is offline   Reply With Quote
Old 10-19-2016, 08:54 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
it could be a bad voltage regulator. before replacing the battery or alternator i would have checked the voltage regulator. most of the time that is really the issue. it is pretty rare that the alternators on these things ever go bad. could possibly be a bad ground connection to the alternator. i am fighting with that issue on my 81. i am too lazy to take it all apart so i currently got jumper cables grounding the alternator
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 10-20-2016, 02:34 PM   #3 (permalink)
pnajera01's Avatar
Ram Year: 1988
Engine: 3.9 LA
Default
I replaced the voltage regulator and the batt is still not charging. I also ran a ground wire straight from the ground post on the alt to the neg batt terminal to see if that was the issue and still no charge to the battery. Dont know what else it could be.
Old 10-20-2016, 03:55 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
have you check to see if there is power being put out at the alternator? does the voltage regulator have a good ground? you may also want to check voltage reading to the voltage regulator and alternator. the 1 wire should be getting 12V
__________________
Old 10-30-2016, 09:44 PM   #5 (permalink)
pnajera01's Avatar
Ram Year: 1988
Engine: 3.9 LA
Default
Finally had some time to do some more digging. I checked the grounds on the v/r and its good. I even went to the extend to ground it to the alternator itself. Ran through all the grounds sanded and cleaned them, they all check good. I turned the truck on and was checking the voltage reading coming out of the alt but before the battery. It said 1.9v. Im not sure if thats what its supposed to be, i assumed it would be 14v since essentially that wire that I was checking is running to the battery.
Old 10-31-2016, 07:12 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
were you checking at on the largest wire at the alternator? if so then yes that should have the same voltage as the battery. you should also see the same battery voltage at one of the smaller wires that hooks to the alternator but you may need to disconnect the wires to see the 12v.
__________________
Old 11-01-2016, 10:27 PM   #7 (permalink)
pnajera01's Avatar
Ram Year: 1988
Engine: 3.9 LA
Default
Yeah it was the largest wire leaving the alt and running to the battery. About halfway on the wire it disconnects and that is where i checked it. Whth the truck on, and the wire disconnected i checked the connecting wire to the alt it was reading 1.9v, but on the end that was connected to the battery it was reading 12v. When the wire is connected and the truck turned off it read 12v all the way to the termial on the alt. No clue what the problem would be.
Old 11-01-2016, 10:40 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
it is possible that you have a bad or broken fusible link. they are on the driver side fender. you could probably get away with running a temporary power wire from the battery to alternator to test to see if that is your issue. if the main power wire is your issue a temporary wire from the alternator output to the battery should have the battery charging.
__________________
Old 11-26-2016, 03:10 PM   #9 (permalink)
pnajera01's Avatar
Ram Year: 1988
Engine: 3.9 LA
Default
Finally had time to figure out the problem! Turns out that along with the alternator going bad, and a bad battery the connector that plugs into the V/r was faulty. When i would put a multimeter to it, it would be getting power but once it was plugged in nothing would happen. So i spliced a plug i had laying around and replaced the v/r yet again, i think oreillys gave me a bad part. So pretty much after damn near replacing the entire charging system it all worked.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
charging system khayhur Engine & Performance 0 10-06-2015 07:05 PM
camper battery charging bcbouy Tech Info 22 09-30-2015 05:40 PM
Battery not charging - new alternator and battery luigi38 Audio & Electronics 16 11-04-2014 01:45 PM
Starter solenoid/alternator/battery junction for dual battery? 12TrueSport Audio & Electronics 10 07-09-2013 06:56 PM
Charging trailer battery willie1990 Exterior 4 04-18-2012 09:59 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
