Roadkill
Hey guys, looking for some help/advice. I've tried researching on ways to bleed the clutch in my 92. However, I kept getting results saying that it can't be done. So I went underneath and found that must be it. It seems to be all one unit, sealed and unable to be bled.
The reason why I want to bleed it is because it's sometimes hard for me to shift into reverse and I have to pump the clutch multiple times before I can finally slide it into reverse. The only way I can think of trying to bleed the clutch is to crack the fill reservoir and pump the clutch to see if that fixes it. Are there any other ways without taking everything apart?
Would this even be a clutch problem? I don't get stuck in reverse, but its just hard to get into reverse without forcing it, which I know is bad.
Thanks.
Thanks.
