Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Engine & Performance
Carb'd 360 Magnum Distributor question
This is a discussion on Carb'd 360 Magnum Distributor question within the Engine & Performance forums, part of the 1st Gen : 1981 - 1993 category!
Hey guys, new to this forum. I'm on here every day searching so figured it's time to sign up. Here's ...
Sponsored By: Moe's Performance
Reply
Old 09-14-2016, 10:47 PM   #1 (permalink)
Ram Year: 1988
Engine: 360 Magnum
Default Carb'd 360 Magnum Distributor question
Here's a little lowdown on my build. I have a 1988 W-100 with Dana 60's swapped into it, along with a 2001 360 Magnum. My friend and I started restoring the truck about 7 years ago and became busy with life and it has been sitting for 5 years so I took it over, replaced the fuel lines, changed the fluids and it fired right up about a month ago.
Okay now for the problem. It has a fuel injection pump in it and a regulator for the Edelbrock 650 carb on it along with an M1 intake. The truck runs and drives but when the throttle is punched, it loads up, backfires, clears up a little but never runs right. It idles fine. It has the distributor out of a 1985 5.9 in it and after timing it, tuning the carb, I'm starting to think my distributor is the culprit.
I pulled the dizzy cap off and noticed the pick-up jiggles around so that's a problem, but I have also read that in order to run right, part of the internals on the distributor have to be swapped up for timing in the higher Rpms, however I can't find any real details on what I need to do..
ANYTHING WOULD HELP AT THIS POINT. I'm very mechanically inclined.. I went to SAM RACING for school but this is the first time doing a swap with a Mopar.
Sorry for the long paragraph but maybe some of the extra details can help someone help me. Thanks in advance!
Sponsored Ad
Register to remove this ad.
B-Slinger is offline   Reply With Quote
Old 09-14-2016, 11:12 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
the pickup shouldn't wiggle or move much unless the screw holding it down is loose or something is broken. what fuel pressure is the regulator set at? some carbs are a bit pickier than others and with the consistent fuel pressure from the electric fuel pump you might be better to be running about 5psi fuel pressure
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 09-14-2016, 11:57 PM   #3 (permalink)
Ram Year: 1988
Engine: 360 Magnum
Default
First off, thanks for replying.. I've noticed on here that you seem to really know your 1st gens. The screw that allows you to adjust the gap on the pickup is there, but I had just noticed before posting the thread, that the plate the screw tightens into and goes under the reluctor moves and in return, throws the gap off.. So tomorrow I'm going to pull the reluctor and make sure nothing under that plate is broken. Maybe there's a clip or spring that popped off. Fuel pressure is set at 5 psi like you had mentioned. One big question I have, is that on a different forum I read about someone who has kind of the same setup, and they say to replace the stop bushings in the distributor in order to get the total timing to 32-34 degrees, however from what I'm piecing together from everyone else, the distributor I'm using should be close to a " drop in and go" distributor.
Old 09-15-2016, 08:21 AM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i am not sure about any bushings in the distributor. i think most of the time people usually talk about the bushing in the engine under the oil pump gear which the distributor drops down onto. it is possible the distributor could be defective. any carbed small block distributor should work if you know someone that has a spare. also don't try pulling the reluctor off to get at the stuff under it. i think it is easier to just push the pin out of the plastic piece at the bottom of the distributor and taking the whole shaft out of the distributor
__________________
Old 09-20-2016, 11:22 PM   #5 (permalink)
Ram Year: 1988
Engine: 360 Magnum
Default
Sorry for the delay. I was out of town for a few days. So here's the update. I installed my other fuel pressure regulator and pressure gauge, along with a New distributor and it seemed to have idled better when the pressure is only at 2 lbs. I'm still having a driveability problem or even if I crack the throttle from the carb while in park it'll pop or blow a flame. I've played with the timing and moved it from 5-18 degrees and it changes the idle of course but still does the same thing. Im starting to wonder if maybe the carb is too large for it. It's an Edelbrock 650. I have the fuel screws on the carb turned out 1 1/2 turns.
Old 09-21-2016, 08:34 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
if it runs better with the fuel pressure set at 2psi it wouldn't hurt to try running it like that. 650 is not too overly large for a 360. definitely on the big side but should still at least run. i can't really give you much advise on tuning the carb since i all i got is holley carbs.
__________________
Old 09-21-2016, 10:13 PM   #7 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
no way 650cfm is too big. the thermo quads that came on 360''s are 750cfm. And I had an 800cfm thermo on my 79 300, and it ran great. Are you running a computer on this truck, or have you retro'd it to pre'engine controller conditions? do you have a vacuum advance on this dist.?
Rustycowl69 is offline   Reply With Quote
Old 09-21-2016, 10:34 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
but a thermquad is a different carb with the tiny primaries and large secondaries. a 650 is a bit of a big carb even for a 360. it might run but it would probably run better with the right sized carb.
https://www.summitracing.com/popup/c...cfm-calculator
__________________
Old 09-22-2016, 12:58 AM   #9 (permalink)
Engine: V10
Default
of course it's a different carb. cfm is cfm. the engine doesn't know or care what kind of carb it has.They are more similar than dissimilar. For one thing, they are both Carters. I ran a 500 carter on a slant 6 4spd, and it worked great. A 650 on a 360 is perfectly acceptable. I am positive his problem has nothing to do with the carb size. But it may have something to do with the carb''s needle and seat, and/or floats. What kind of condition is it in.
Where did this carb come from? Did it come fresh off a running engine, or has it been kicking around in somebody's trunk for a few years?
Old 09-22-2016, 03:08 PM   #10 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
Another suggestion would be that the vacuum advance to the distributor isn't hooked up properly.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
5.9 Magnum question. jared.hammel Engine & Performance 2 06-03-2016 04:18 PM
Question to Ram 5.9 V8 Magnum users Szarbia Tech Info 1 04-25-2015 05:13 PM
Question about changes in the Magnum BlackMagnum2000 Engine & Performance 4 01-26-2014 10:44 PM
Carb Question on 1988 w150 318 BurrowsRacing33 Engine & Performance 11 08-01-2013 04:06 PM
Carb swap and intake manifold question SCme Engine & Performance 1 04-05-2013 05:26 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
