caseykeenum
- Mar 8, 2013
- 26
- 0
- Nesbit, Mississippi
- 1990 D150
- 2000 Ram 5.2L/318
Alright everyone, I have a 1990 Dodge D150 that is my project truck. It has the stock V6 and a 5 speed that I am not 100% sure came with it or was swapped into it before I got it. I just picked up a wrecked 2001 Dodge Ram 1500 that was only wrecked in the front (bumper mainly, little bent in the core support). Was parked after the wreck and abandoned for something better than 5 years, I paid only $400 for the truck. It has a fuel injected 318 which I would like to swap into my 90 D150. I know the engine is not seized up and this weekend I am going to bust the ignition to see if I can at least attempt to bump over the engine. If that works or fails I will go ahead and pull it because it should still be in good running order. Now to the questions. I know I will have to pull all of the wiring and ECU and such considering it is fuel injected which is cool with me. Will I have to take the steering column as well? Or is my better option to scrap the fuel injection and go carburetor? Will the 318 bolt up to the 5 speed tranny (knowing full well I still need to provide you all with what it is, just hoping you might know up front). What if anything will I need to expect to obtain in order to get it to sit in the D150? It looks like an exciting project overall and if you would like to know what else I plan on doing to it just ask.
