So, Ive got a 1990 W250, runs fairly well but is getting to be elderly. Thinking about buying a newer, maybe 1995-2002 5.9 to put in it. I know I will have to pull all the electronics to make it work but questions....
1. Will it bolt up to the 4 speed manual transmission (32RH???) thats already in the truck? If no, then would the newer transmission be an easy swap?
2. Will the engine mounts need to be relocated?
3. Will the electronics actually work?
4. Is this a bad idea?
5. If I stick with the carbed engine, where's a good place to get a crate engine on the cheap?
