ray hall
- Jan 28, 2014
- 35
- 2
- 1983
- 225 slant six
Hi i have a 1983 dodge w150. It has a slant sixe with the np435 4 speed. I bought a 360 to put in it and i got a bellhousing out of a 78 3/4 ton 2wd. I was told the bellhousing would fit i just need to grind the inside a little for the bigger flywheel. How will the starter work if the flywheel is bigger? Is the guy correct? At oreilly autozon and google the 360 flywheel is 14.5? Inch total diameter and the 318 is 13.216. If u go to napa they say the 360 is 12 1/16 and the 318 is 12 3/16. So i bought the 360 flywheel from napa because their numbers sound like it will bolt up and work. Will this work together if not wat do i need?
