I have had a 1992 D150, 2wd with a 318 magnum engine for a while now. the Engine and transmission are great. The body and frame, however, not so much after a recent encounter with a rather unforgiving tree.
I have bought a new truck in the mean time. This one is a 1989 D150, 2wd with a 318 engine too. This engine is....o.k. at best. It runs and all, but has a coolant leak I have not been able to pinpoint quite yet, and overall needs work.
One thing is clear though. There is a remarkable difference in performance between the two engines. The Magnum is of course a newer engine and likely better maintained over its lifetime. The Magnum is still factory and the older engine has clear signs that someone messed with it at some point.
Which leads me to the following question: Is it possible to swap the engine and transmission from the 92 and put it in the 89 truck? if so, what challenges can i expect to run into?
I am enthusiastic DIY, but I have not done anything on this scale before. I'll likely call in some help, but even so, I would like to get a good idea what i am getting into.
So, it is worth swapping the engines, or should I just try to make the older engine work better?
Any wisdom is much appreciated.
