Hi All, first post here. I recently bought a 1990 Ram that seems to have some type of ignition problems (my speculation anyways). Under heavy throttle application the engine bogs, I tried adjusting the timing, although I'm not sure I got it right. The emissions tag says 10 BTC, but both the block and harmonic balancer have scale on them. I tried setting the 10 BTC on the balancer to the 0 on the block (idles poorly and will stall in gear if brakes applied), next I tried setting the 0 on the balancer to the 10 BTC on the block (idles nice but is gutless under throttle and bogs still.)
Also there have been a whole host of other mods:
Converted to run propane
Converted back to run gasoline
Headers with dual exhaust
Holley throttle body
Looks like the EGR valve is gone and blanked over.
Any input would be appreciated. Thanks
