I_chew_big_red
Hey all. I just picked up a 1985 Dodge W150 Power Ram Royal SE. It's got ~173,000 miles, a 318, 3 speed auto, 4x4 on the floor, and has a 4" Rough County lift. It's got a handful of problems and I'd like some advice on how to go about fixing her up.
Here are my issues:
1. The Oil Pressure gauge doesn't work
2. The Water Temperature gauge doesn't work
3. The Battery gauge doesn't work
4. The steering is very sloppy and loose. I can turn the wheel six inches either way with no response. The steering column is covered in grime.
5. It's leaking some sort of fluid under the oil pan and at the u-bolt connecting the drive shaft to the tranny. The u-bolt is covered in grime and there was a puddle about 1 foot across on my driveway the day after I drove it home. The puddle formed where the cab meets the truck bed, which I thought was too far back to be engine oil. The puddle is brownish black, and I can't determine if it's engine oil or tranny fluid. 6. Starting the truck is hit or miss, and when it doesnt start, I can hear something spinning inside the engine compartment. I think it's the starter not engaging the flywheel, but I don't know for sure.
7. The radiator cap leaks
8. It throws out a lot of white smoke on start-up, and smells like it's burning oil or coolant when driving.
9. The brakes are very stiff and I have to really press down on the brake pedal to stop the truck in a reasonably short distance.
This is embarrassing to admit, but I don't know the first thing about engines, or really trucks in general. It drives pretty good, minus the loose steering and hard brakes. What repairs should I be focusing on first, and what repairs can I do myself. I'm good with tools but never worked on an engine before. Is there a diagram of the engine somewhere online so I can see what all these parts are under the hood?
Here are some pictures: Imgur: The most awesome images on the Internet
Here are my issues:
