Hotrod A
The truck is an 88 w250 with the 318. What should the oil pressure be, either in psi or if you have the stock gauge where on the gauge does the needle point? When I got my old ram I thought the oil pres. was really low so I replaced the oil pump, but the gauge stayed the same. Now this truck looks to be the same as the old one. Thanks, Rob
