ray hall
- Jan 28, 2014
- 35
- 2
- 1983
- 225 slant six
Hi I have a 1985 dodge w150 that has a 360. It had oil pressure because it shot oil out of the sending unit hole by the distributor. It had a big dent in the oil pan where the pick up tube is so I was afraid it might cause a problem. So I took the pan off and beat the dent out and I thought I would put a new oil pump in it while I was right there. I stuck it in oil and turned it over and primed it up before I put it on. Now I have no oil pressure. It fills up the oil filter and if u take it off it shoots out of the hole but it won't pump into the motor. The rockers ratlle really bad and I have clear oil line on the port by the distributor hooked up to the gauge and I can't even get oil into the line. I have tried a new filter and put a second pump on. I don't know what the problem is I was hoping I can get some ideas. Any help will b greatly appreciated . Thanks
