GeneralBamboo
- Nov 24, 2015
- 8
- 0
- 1985
- 360 V8
Awesome site here, finally ran into a problem I cant solve by just searching now....
So my grandpa gave me his 1985 Dodge D250 truck [12X,*** miles] since he is no longer able to drive and I have been working on fixing it up as it has sat for a while. Its got a 360 5.9L v8 with a Rochester quadajet 4bbl carb.
We had the truck shipped down here and replaced the ignition control module and it has ran pretty well for a few months. I decided to rebuild the carb and purchased a rebuild kit from O'Reilly's. I thoroughly cleaned the carb just like i do with any other carbs I work on, checked and set the float level, and thoroughly cleaned all passages.
We put the carb back on the truck and it started up but ran really rough. We took it down the street and anytime you gave it gas it just wanted to die. we came back to it the next day and started it up and it would shake pretty bad and hesitate and die when you put it into gear. Now it wont even start, even with starting fluid.
Things that are new on the truck:
Ignition control module
ballast resistor
coil
distributor cap
sparkplugs and wires
The fuel pump is pumping and the plugs are getting spark. I can press down on the accelerator pump and see it squirting fuel into the intake.
Any ideas on what we need to check next? We cant even get it to pop off or anything with starting fluid.
ballast resistor
coil
distributor cap
