Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
1985 Dodge Power Ram W150 steering
This is a discussion on 1985 Dodge Power Ram W150 steering within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
So, my ongoing projects with my Power Ram includes removing the slop from the steering. I've determined some of the ...
Reply
Old 11-25-2016, 12:56 PM   #1 (permalink)
Brucecmc's Avatar
Ram Year: 1985 Power Ram W-150
Engine: 318 V8 5.2L
Default 1985 Dodge Power Ram W150 steering
So, my ongoing projects with my Power Ram includes removing the slop from the steering. I've determined some of the cause of this slop is a coupling between the end of the steering column and the steering box.
I believe this coupling is called the "steering shaft pot coupling" but I need to know for sure and if at all possible, where the heck do I get a part number for it. see attached diag
honestly, i'd like info on where I can find parts (especially with diagrams) so I can quit coming out here and pestering ya'll with the basics (identifying parts).
thanks in advance.
Bruce
Sponsored Ad
Register to remove this ad.
Brucecmc is offline   Reply With Quote
Old 11-25-2016, 12:59 PM   #2 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default steering coupling
heres another picture. this is the actual coupling...to the right goes to the steering shaft, to the left is the steering box
Old 11-25-2016, 02:02 PM   #3 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
have you tried turning your steering shaft to verify that is where your slop is. only reason i ask is because it looks like someone has probably already rebuilt the steering coupler at one point which is why there is a grease fitting on it. it is really up to you but i think the borgeson steering shaft is really the only permanent fix but they are a bit expensive. you can get a steering shaft repair kit but it may not really do much. DORMAN 425253
https://www.rockauto.com/en/catalog/...pair+kit,13574
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 11-25-2016, 02:45 PM   #4 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
hey wolfie...here we are again...
well, I've considered the borgeson steering shaft (and haven't ruled it out), but I was trying to keep the truck original (as much as possible), I think that would be the perm fix as well...if it was rebuilt before, it seems it needs it again...I don't know if you can tell from that picture, but there is a seal that is destroyed poking out the end of it...and yes, theres a lot of wiggle in that joint and you can see the shaft turn (along with this coupling) quite a bit before it actually engages the steering box spline...
I'm assuming I have to take the Rag Flange apart in order to ultimately get that coupling off....and I noted, there seems to be what looks like a "straw" sticking out of a small hole on that housing for the coupling.....any idea what that is?
bruce
Old 11-25-2016, 04:42 PM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
haha ya the first gen section is pretty small lol.
from my experience every time i have taken one apart even if i re-used the stock parts i could still never get the steering coupler tight. usually the moment you wash the mud like grease out you end up with slop. i have been told the stock mopar coupler rebuild kits were better for tightening things up but they are almost impossible to find and even then they only last so long.
you do require a 5/16" roll pin and a 12 point 3/8" socket to removed the steering shaft on top of all the basic tools needed to drop and disconnect the steering box.
the straw is likely to let extra grease out. does the whole coupler turn back and forth a bit before the output shaft turns or does the shaft going into the coupler turn back and forth inside the coupler?
__________________
Old 11-25-2016, 05:29 PM   #6 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
The shaft turns inside the coupling before it engages the spline poking out of the steering box. I got the rag flange apart, now I need to get the lower part of the shaft and pot coupler off the spline on steering box. Do you have to have a special tool for that because it certainly doesn't just pull off.
Old 11-25-2016, 06:00 PM   #7 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
do you mean how does the pot coupler come off the steering box? After removing the roll pin, yes, it just slides off the splines. But yours looks pretty rusty, so it might be a little sticky. What's the deal with the hose clamp on the right side of the pot coupling?
Rustycowl69 is offline   Reply With Quote
Old 11-25-2016, 06:28 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
see that dowel pin in the first picture you posted that hold all the stuff in but even then you still usually need to drop or lower the steering box to make enough to move the steering shaft away from where it connects to the steering column.
@rusty i have pulled couplers off worse. they usually come off pretty easy and having the roll pin punch makes the job very easy.
__________________
Old 11-25-2016, 07:15 PM   #9 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
No idea what the guys before me were doing with that clamp. And that's the odd thing about this. The only hole in the coupling is one that has what appears to be a straw poking out of it. Doesn't appear that a roll pin goes thru the coupling, into the shaft. I'm quite confused by this
Wolfe, I disconnected that rag flange up stream, so the bottom section of the shaft is free floating now. Just begging me to pull the coupling off. Lol.
Old 11-25-2016, 07:27 PM   #10 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
if there is no roll pin holding the coupler to the steering box then yank it off. sometimes a wrench makes a pretty good pry bar for that job. there is most likely a dowel pin holding the other stuff in is easier to get at with the shaft not on the truck.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1985 Dodge Ram W150 won't start unless ignition on Brucecmc General Discussions 4 12-14-2016 09:44 PM
Horn doesn't work 1985 power ram W150 Brucecmc General Discussions 24 12-08-2016 12:34 PM
1985 W150 repairs. Am I getting ripped off? I_chew_big_red General Discussions 3 05-07-2016 07:24 PM
1985 W150 Power Ram Deamer Member Trucks 10 04-14-2014 07:58 PM
1985 w150 acts like it runs out of gas when passing jcp dodge Engine & Performance 4 02-20-2013 12:19 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
