Codes 24 and 33
D
dev199505
hard to say. what shape are the fuel lines in? if they look decent and there is not any obvious leaks i would probably leave them. i think if you are loosing pressure and you don't have any fuel line leaks it can sometimes be the fuel pump or fuel pressure regulator. i forget which or if it could be both.
Ill replace the fpr hose and see if that helps if not then ill do the pump fpr will be last since its the most expensive part lol
Sent from my LG-K373 using Tapatalk
yoda
Are you still running on year old fuel? If so don't replace anything until you get a fresh tank of fuel in it.
D
dev199505
No ive gone threw quite a few tanks and a bottle of fuel system cleaner
PhillyGoat
Pacific Northwest
So I had a similar issue, and I checked a connector that is above the brake/acceleration pedals that had come a bit loose. I pushed it back together and the problem hasent recurred in six or seven months.
PhillyGoat
Pacific Northwest
I think mine was the accelerator position sensor quick disconnect located by the pedal.
D
dev199505
Thanks ill take a look
D
dev199505
Do you got a picture? I dont see anything
crazzywolfie
under the truck
haha i don't even think he knows what type of truck you have. there is no sensors in your cab that should make your truck hard to start or cause it to run rough. all the sensors and things needed to make your truck run is under the hood.
[yt]9U2p610t7Xs[/yt]
D
dev199505
Ok i have to check sensors guy who redid wiring didnt even put stuff up where it should be its all just dangling around under the dash
crazzywolfie
under the truck
that stuff dangling under the dash shouldn't effect how the engines run or performs. you can power the asd relay under the hood and bump the starter and it should fire up. that is how i did it in that video. i also installed my remote starter in my 93 the same way. all it took was 2 wires.
D
dev199505
Wheres the asd?
crazzywolfie
under the truck
the ASD relay is one of the relays bolted to the drivers side fender. you don't need to worry about them since it don't sound like that is an issue. it just power everything under the hood when you turn the key on.
D
dev199505
Ok, if it is a bad sensor where should i start looking? I noticed a small popping noise when it doesnt start and i let off the key
crazzywolfie
under the truck
i am not sure. you would almost need to test each sensor individually to see which one might possibly causing issues if you are having a sensor related issue.
D
dev199505
Ok thanks
D
dev199505
Could it be a weak starter or bad coil? Also what do you think the popping im hearing is?
PhillyGoat
Pacific Northwest
Yeah, sorry, didn't look at what year his truck is. Mine is '12.
crazzywolfie
under the truck
does the engine spin slow? usually starters don't go bad too often. usually a bad coil would likely cause a consistent issue like turning the engine off when hot. that pop when you turn the key off is likely just the fuel in which ever cylinder the rotor is closest to pointing at being ignited. the moment you take power away from the coil it usually creates a spark. my 81 is bad for doing that when the battery gets low or has a bad connection at the battery.
i just know from tapatalk you usually don't see any of the information off to the side like you do in a web browser
D
dev199505
No its spins fast but some time it makes a whining noise sometimes it doesnt
txram956
