Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
Couple issues,
This is a discussion on Couple issues, within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
My brights are always on (when headlights are) I don't have any low beams, the dimmer switch isn't on the ...
Reply
Old 12-14-2016, 08:00 AM   #1 (permalink)
Ram Year: 1988
Engine: 5.2
Default Couple issues,
My brights are always on (when headlights are) I don't have any low beams, the dimmer switch isn't on the floor and pulling turn signal switch forward does nothing, is my '88 suppose to be on the floor? Looked under the dash and I found this but nothing else, also I'm not sure how to use the windshield washer pump, I can't find the trigger, originally I thought pulling the blinker switch forward activated that but after not finding the dimmer switch on the floor I'm not sure and it's got me really confused, I've worked on vehicles before so this is really throwing me off
Sent from my Coolpad 3622A using Tapatalk
Sponsored Ad
Register to remove this ad.
dev199505 is offline   Reply With Quote
Old 12-14-2016, 12:13 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
you pull the wiper switch back towards you to jump between highs and lows. to use the windshield washer pump you press the end of the wiper control stick in
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 12-14-2016, 12:41 PM   #3 (permalink)
Ram Year: 1988
Engine: 5.2
Default
But the end doesn't push in, so maybe my switch is just bad, does steering wheel have to come off to change it?
Old 12-14-2016, 12:56 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
is the wiper switch on the steering column or on the dash beside the headlight switch?
__________________
Old 12-14-2016, 01:32 PM   #5 (permalink)
Ram Year: 1988
Engine: 5.2
Default
Steering columm
Old 12-14-2016, 01:38 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
does the truck also have cruise or delayed wipers?
__________________
Old 12-14-2016, 02:19 PM   #7 (permalink)
Ram Year: 1988
Engine: 5.2
Default
No cruise does have delayed wipers, the end of the knob does push in just very small amount, I found the dimmer switch button but it's not connected up top anywhere I'd have to get under the dash to turn it on and off, any idea where it's supposed to mount?
Old 12-14-2016, 04:33 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
that small amount is all that it needs to activate the pump. you can test it with a test light but it would not surprise me if the washer pump possibly died.
if it the switch is just hanging there there is a possibility that parts might be missing to have it in the stock spot. it usually bolts to the steering column and there is a rod that connects to to the wiper/turn signal switch. if stuff is missing you could possibly install a floor mounted dimmer switch
__________________
Old 12-14-2016, 05:39 PM   #9 (permalink)
Ram Year: 1988
Engine: 5.2
Default
I believe that rod is missing, floor dimmer switch it's only $6 so I'll do that thanks, and previous owner said the pump was so bad so I'll replace that at some point lol
Old 01-07-2017, 08:43 AM   #10 (permalink)
Ram Year: 1988
Engine: 5.2
Default
Guys recently my truck has developed a surging idle when cold (it's any where from 10 to -10 in the morning) what should be the first thing I check
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A couple issues ckeefer58 Engine & Performance 8 11-25-2016 06:33 AM
Need HELP. Couple of issues please guys JinxCanada General Discussions 6 04-14-2015 09:48 AM
First post and couple of issues wagner83 Audio & Electronics 4 06-07-2014 02:02 AM
Couple new issues Hollabakzach23 Engine & Performance 4 07-31-2012 10:13 PM
Troubleshooting a couple issues... WhiteExpress General Discussions 7 09-21-2011 10:34 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
