Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
Marshmallow Brakes
This is a discussion on Marshmallow Brakes within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
I step on the pedal and it feels like marshmallows. The truck stops but not well. My uncle who owns ...
Reply
Old 11-03-2014, 01:50 PM   #1 (permalink)
dwysywd's Avatar
Ram Year: 1983 D350 CCSB
Engine: 360ci
Default Marshmallow Brakes
My uncle who owns a repair shop suggested I bleed the brakes. I have done this on my motorcycles with success...but never a 4 line system.
suggestions or is this one of those deals where I'm just better off paying for it?
I need to replace a damaged rotor on the front, I could have it done then too I guess.
Sponsored Ad
Register to remove this ad.
__________________
Sent from my bag phone...
MY RIG BUILD LINK
dwysywd is offline   Reply With Quote
Old 11-07-2014, 09:22 AM   #2 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
Bleeding the brakes is pretty straight forward. Have someone on the cab pumping the pedal, I usually have the engine off. Then with someone standing on the pedal open the bleeder screw to let some fluid out. Be sure to close the bleeder screw before the pedal goes all the way to the floor. Start with the wheel furthest from the brake cylinder and male sure the cylinder is always full so you're not sucking air back into the lines. I usually bleed each line 3 or 4 times.
I just did the front brake rotors on my W350 and although it was more difficult than doing them on my 1/2 ton trucks it wasn't too bad. Just more time consuming. If you know what axle you have I could post up some pics.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Old 11-07-2014, 09:37 AM   #3 (permalink)
dwysywd's Avatar
Engine: 360ci
Default
I have Dana 60s. I have 1983 W350
__________________
MY RIG BUILD LINK
Old 11-07-2014, 11:15 AM   #4 (permalink)
RonJon '06's Avatar
Engine: 5.7, 360
Default
I have a Dana 44 on the front but it looks like it goes together the same. The spindle nut socket (left) cost around $20 and I had to grind down two of the prongs to get it to fit.
I also bought a snap ring removal tool for $12 to take the hub apart.
When I got the hubs off I pounded out the studs using a 3/8" socket extension and was able to reuse all of the studs.
When putting everything back together I packed the wheel bearings and tightened the spindle nut enough so that the wheel still spun freely but there was little to no play in the hub. It took some effort to get them snug again, I ended up having to tighten the lug nuts in a criss cross pattern several times to pull the rotor snug with the hub. It would have been much easier with an impact wrench.
I watched this video before doing my brakes and thought it was very helpful.
Dana 60 Axle: Hub and Brake Disc Removal How-To - YouTube
__________________
Old 11-08-2014, 02:17 AM   #5 (permalink)
Ocelot's Avatar
Ram Year: 2011
Engine: 4.7
Default
When I bled my brakes after replacing a rubber brake line, I picked up a pistol grip hand vacuum pump and was able do do it perfectly without a helper. It was much easier than the way I used to do it with a helper pumping the brakes and when I was done, the brakes were great. Nice and solid.
This is the one I used:
OEM/Vacuum pump 25136 at AutoZone.com - 7 reviews
Ray
__________________
2011 Ram 1500 SLT Quad
Ocelot is offline   Reply With Quote
Old 11-08-2014, 08:49 PM   #6 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
bleeding the brakes probably won't do much. the rear brakes are most likely out of adjustment and the adjuster is most likely locked up and no longer doing its job. also if you have not replaced the brake lines on the truck you may want to inspect them and possibly replace them. may also end up replacing wheel cylinders and calipers just because the bleeder screws are most likely rusted shut.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 11-28-2014, 12:52 AM   #7 (permalink)
dwysywd's Avatar
Engine: 360ci
Default
Ok so checked everything out. Rear adjusters worked great. Front and rear bled fine...and then the brakes got worse. So I ordered a new MC based on my uncle's professional opinion...he owns several repair shops and his best guy helped me do the work. I will have it installed next week.
__________________
MY RIG BUILD LINK
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"Marshmallow" Build thread Harrisb Member Trucks 18 06-04-2013 11:33 PM
Brakes.. jtoscano19 General Discussions 9 01-20-2012 03:47 PM
New brakes on the way! The Assassin General Discussions 8 11-15-2010 11:58 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
