Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
No Headlights
This is a discussion on No Headlights within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
So I've been searching around for a while and had found a couple similar situations others have had but their ...
Reply
Old 10-01-2015, 06:14 PM   #1 (permalink)
Ram Year: 1989
Engine: 360
Default No Headlights
So I've been searching around for a while and had found a couple similar situations others have had but their solution has not solved mine yet.
My headlights had been intermittent for a bit where they would work for a while, then they wouldnt work for a while to the point where they would flicker and then stay out.
my running lights would still work, my high beams when held, would stay on, but my low beam headlights would not come on still.
I replaced the headlamp switch as it seems to be a common failure but i am still having the same issue.
I have the entire dash apart and have found that it seems there is a loose wire possibly because when i have my headlamp switch turned on, the running lights are on, but the buzzer does not stay on constantly (engine off) like it usually does to remind you to turn your lights off. sometimes when i move the harness it goes on and off.
in short, my headlights wont stay on.
I have been unwrapping all the factory harness's in the dash and have yet to find a bad wire/loose wire.
any other ideas what i could be looking for??
im lost even with the factory wiring manual.
Sponsored Ad
Register to remove this ad.
__________________
1989 Dodge D150
2007 Jeep Wrangler JKU - Sold
2012 Ram 1500 Laramie
Matteo is offline   Reply With Quote
Old 10-01-2015, 07:42 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
well since your high beams work your issue is in the wiring between the dimmer switch and headlights themselves. should be fairly easy to narrow down. i would possibly be looking at ground wires under the hood. you could try doing a resistance test between the headlight connector and the dimmer switch connector.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 10-01-2015, 09:23 PM   #3 (permalink)
Ram Year: 1989
Engine: 360
Default
Found my issue.
__________________
1989 Dodge D150
Old 10-01-2015, 09:34 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
that would do it. that is one of the reasons i recommend installing a relay harness on any old truck especially if you are daily driving them. the weak spots in the electrical sometimes show up like that.
__________________
Old 10-02-2015, 12:21 AM   #5 (permalink)
Ram Year: 1989
Engine: 360
Default
Already ahead on that one. Made this harness and installed it.
__________________
1989 Dodge D150
Old 10-02-2015, 04:45 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
looks good but seems like you are a bit late tho lol. at least you shouldn't have any future issues with the lights and they should be noticeably brighter.
__________________
Old 10-19-2015, 02:03 AM   #7 (permalink)
DodgeAddict's Avatar
Ram Year: 1985
Engine: 5.9 Magnum
Default
The original issue that caused that is a bad ground
__________________
I have the CC DD chromosome in my DNA
DodgeAddict is offline   Reply With Quote
Old 10-19-2015, 09:17 AM   #8 (permalink)
The War Wagon's Avatar
Ram Year: 1992
Engine: 318 Magnum
Send a message via Yahoo to The War Wagon
Red face
Don't know how much salt they use on winter roads in Calgary, but it's MURDER on our trucks down here. It's always a challenge to see which goes first around here - the rockers, the floorpan, or the electrical.
It's the MAIN reason Gen1's are so scarce in the northeast and upper midwest anymore.
__________________
"Me & my RC - me & my RC!!!"
The War Wagon is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
want to trade black projector factory headlights for chrome projector headlights goddard2335 Wanted 11 04-12-2015 06:15 PM
06-08 Headlights bigbadram1500 Wanted 7 11-14-2013 07:23 PM
2013 Sport Headlights vs. 2013 SLT Headlights Ram-NB Exterior 17 01-24-2013 02:16 AM
Will 07-08 headlights fit on an 06? WhiteRam Exterior 11 12-22-2011 09:52 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
