Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > 1st Gen DIY
1st Gen DIY
1992 d150 fuel pump
This is a discussion on 1992 d150 fuel pump within the 1st Gen DIY forums, part of the 1st Gen : 1981 - 1993 category!
Hey guys I got a new to me d150. I've done a little maintenance but now it's time to replace ...
Reply
Old 11-14-2015, 09:23 PM   #1 (permalink)
evanblain's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default 1992 d150 fuel pump
Hey guys I got a new to me d150. I've done a little maintenance but now it's time to replace the fuel pump. Anybody have any tricks to remove the tank fill and vent lines or the quick connect to the pump it's self. Thanks.
Sponsored Ad
Register to remove this ad.
__________________
Mods: 1.5" Level, 285/60/20 Duratracs, Debadged, Tinted Tail lights and third brake light, Added cabin air filter, Projector HID headlights custom painted, BT catch can, electric cutout, black honeycomb grille, pdipped emblems and rims
Future mods: Led bulbs, possible custom badges, tint windows
evanblain is offline   Reply With Quote
Old 11-14-2015, 10:53 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
does the pump itself still work? if so just leave it alone. the stock ones are just as good if not better than any aftermarket one out there. if it is bad then there is really nothing to dropping the tank on a truck. just unbolt it and drop. you pull the plastic locks off the fuel lines and just twist back and forth off the sending unit.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 11-14-2015, 11:13 PM   #3 (permalink)
evanblain's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
It's this guy that I'm worried about. Then theirs a plastic connector on the hose behind it. I was thinking about busting the little nipples off the old pump then worrying about them after I get the tank out. And for the fill line just try to take it off at the tank?
__________________
Old 11-14-2015, 11:32 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
you are best to get the tank onto the ground and then pull them off. from my experience that connector does not look right for these vehicles. should be plastic connector connecting to the sending and i think the line to the frame is also suppose to be some sort of plastic or at least it is usually when stock
__________________
Old 11-14-2015, 11:48 PM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
the stock connector and lock clip should have looked like this
__________________
Old 11-15-2015, 09:15 AM   #6 (permalink)
evanblain's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Yeah it's probably a replacement line. I believe the connector behind it looks like that one.
__________________
Old 11-15-2015, 11:02 AM   #7 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i wouldn't worry about it too much. if you drop the tank and can disconnect it at the other end so you can get the tank out it might make the line easier to remove from the sending when working on it while not under the truck especially if that is the type of connector i think it is. i think you will need tools like this to remove that connector if it is the type i think it might be and even then it is a real pain in the ass.
A/C and Fuel Line Disconnect Tool | Princess Auto
also if you do damage that connector i don't think it is a big deal i am not 100% sure which one that is but i think they should have replacements and if all else fails you could probably get away with fuel line and hose clamps.
doorman part numbers
800-053 http://www.dormanproducts.com/gsearc...word&q=800-053
800-054 http://www.dormanproducts.com/itemde...SEName=800-054
800-055 http://www.dormanproducts.com/gsearc...word&q=800-055
__________________
Old 11-24-2015, 04:41 PM   #8 (permalink)
evanblain's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Hey Crazy or any one really. I got the whole pump changed except this fitting. I broke it off the old pump just to speed things up and now I can't get it out to attach the hose to the new pump. I bought one of those tools you linked but the piece inside the fitting isn't perfectly round. Anyone got an idea or should I just rip the hose off the truck and replace it.
__________________
Old 11-24-2015, 08:29 PM   #9 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i hate to say it but you may end up needing to replace the fitting. you could try drilling the plastic out but it will still most likely damage the seal.
__________________
Old 12-08-2016, 01:23 PM   #10 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
I just did this on my 1991 W150. I decided to NOT drop the tank because right before the pump went south, I filled the damn tank! Soo, I did the truck bed tilt way. Worked out very easy and was a breeze. Those connectors are easy to get off safely if you are careful if you have room. And you have plenty if you tilt the bed. If you want me to walk you thru the tilt bed how too, let me know here and I'll do it happily. But generally, there is a clip in the connector that is or used to be white plastic, it is probably yellowed by now. When you have the bed u-p and out of the way before you do anything else pinch the clip with a tiny slim needle nose plyer and just pull the hose straight off.
Don't force anything and you'll get it.
to tilt the bed simple remove the two bolts in the front of the bed, and the two center ones, halfway loosten the back two and then hook up a engine hoist to the fornt of the bed and simply tilt it up outta the way for safety use a couple jackstands under the bed between it and the rails and you'll have all the room you need. Here's a video on a 1996 but it is the same proceedure. Don't worry about the pressure deal he explains because the tbi trucks have low pressure.
https://www.youtube.com/watch?v=XZSPFxthp0k
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fuel pump is going out... rammanriley20 General Discussion 12 07-08-2015 06:34 PM
Fuel Problem, not the fuel pump pwebyd90 Tech Info 23 04-23-2015 07:31 PM
Cannot Find Fuel Sending Unit for 84 D150 Yoox_II General Discussions 1 01-30-2015 02:32 PM
Fuel Pump? sabre Engine & Performance 2 12-09-2013 06:23 PM
Fuel pump Luke(MI) Tech Info 3 07-26-2011 11:50 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
