Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > 1st Gen DIY
1st Gen DIY
2 barrel to 4 barrel conversion
This is a discussion on 2 barrel to 4 barrel conversion within the 1st Gen DIY forums, part of the 1st Gen : 1981 - 1993 category!
Hi there all. I have been debating on converting my 2 barrel carb to a 4 barrel and would like ...
Like Tree1Likes
  • 1 Post By crazzywolfie
Reply
Old 09-13-2016, 11:57 PM   #1 (permalink)
Ram Year: 1990
Engine: 360
Default 2 barrel to 4 barrel conversion
Hi there all.
I have been debating on converting my 2 barrel carb to a 4 barrel and would like to know what else I would have to convert on my 1990 360.
Thanks for any input
Sponsored Ad
Register to remove this ad.
Allenrench is offline   Reply With Quote
Old 09-14-2016, 03:47 AM   #2 (permalink)
crash68's Avatar
Ram Year: 2015
Engine: 3.0 EcoDiesel
Default
90's were fuel injected from the factory. That "2 barrel carb" is the throttle body injection. Unless someone removed all of the electronics and added a carb, why someone would do that only to install a 2 barrel is baffling.
If your looking for more horsepower, you need a tuner.
crash68 is offline   Reply With Quote
Old 09-14-2016, 10:21 PM   #3 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
if everything is working fine you are best to leave it as is and be happy with it. sticking a 4 barrel would likely not gain you anything other than it costing you money. the TBI system that is on the truck would likely create the exact same amount of power as a 4 barrel.
@crash there is no tuners available for these trucks. there is performance computers available for od1 trucks with magnum engines like my 93 but they are still very limited and not really tuneable.
crash68 likes this.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 09-14-2016, 10:24 PM   #4 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Question: Isn't a 90 an LA engine? My 91 Dakota has a LA 318.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 09-15-2016, 06:50 AM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
yes a 90 would be an LA engine. they used them all the way up till 91 for the 239/318 and 92 for the 360
__________________
Old 12-08-2016, 01:31 PM   #6 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
IF you have a 2bbl carb, and are not thinking the TBI is a carb, the way to do what you want entails a lot of work. First off to do a 2bbl to 4 bbl swap the right way you really need to go to a hotter cam. Otherwsie a 4 bbl will be no benifit at all and might be a step backwards. Second, on a 90s vintage 318 or 360 a 4 bbl will have to be a small one to work at all. If you still want to do it get a cam made for the chrysler small block that is in the middle of the street strip range and a 500cfm carter carb and a good aluminum intake, and a phenolic spacer.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Switching from 2 barrel to 4 barrel Yoox_II Engine & Performance 3 12-22-2015 06:34 PM
2x4 conversion to 4x4 Terrance General Discussions 13 04-13-2014 07:18 AM
What exactly is a HID Conversion Kit? X Justus X General Discussions 6 10-14-2012 02:01 AM
Double barrel 1911 .45cal truckin151 The Great Outdoors 13 04-27-2012 11:03 AM
426 Conversion truckin151 Engine & Performance 12 01-30-2011 12:44 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
