MOPAR OEM CHMSL (Third Brake Light) Cargo Cam for All Trucks
shaftman_05
Southern Michigan
Ok so today I got the harness and a camera that customtronix sends you with the purchase of the silver rax jailbreak. It arrived 5 days at my door after purchase, sweet! The camera says rear view, but I cant see why it cant be used as a front camera. It's pretty small. It comes with mounting hardware, a drill, and a really, really long rca video cable.
The harness that plugs in between the radio and the original cable, has an rca aux connector, and 2 rca video inputs. The aux cable splits into 3 wires at the end (red, black and white) I dont know what what is though. The video cables split into 2 wires at the end (black and yellow). Hope this helps somebody along the way.
The third brake light still didn't come in the mail, so I don't really know how that is going to work out yet.
The o.e. third brake light uses a very odd connector. One I still haven't managed to source yet... without it this project is a bust.
biwanow
Canada
2013 Dually Laramie Longhorn
Cummins 6.7
How did Jeepguy manage to do it?
biwanow
Canada
Cummins 6.7
Maybe the dealer can supply us with a harness...
biwanow
Canada
Cummins 6.7
Could you upload a photo of the camera connector?
shaftman_05
Southern Michigan
Not a legit pic but a screenshot of the parts breakdown.
biwanow
Canada
Cummins 6.7
According to Jeepguy, the backup camera in the latch, has the same connector as the chmsl camera. If we could get a connector like that, we could probably figure out how to make a harness that has the 6 pin end to 12v and rca video.
shaftman_05
Southern Michigan
I can check that. But fairly certain they are different.
shaftman_05
Southern Michigan
Found the pic. Its the same but part number is different. I will check monday when I can get near some of the parts.
biwanow
Canada
Cummins 6.7
Sweet. What's the part number for that cable? How do you have access to DealerConnect?
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
I was able to remove my tailgate cover and plug in the oem CHMSL into it, I engaged the truck in reverse an the camera functioned. The part for this cable is 68189124AB.
http://www.tascaparts.com/oe-mopar/68189124ab?search_str=68189124AB
Sale Price: $29.46
it looks like jeep guy used this cable and spliced it into his own custom harness. FYI the part I listed hay a y connection going to the locking tailgate mech, it may be avail without it but you should be able to hook it into your own fabbed up cable.
FYI the part numbers for the two connectors are the same, X41087-AM-X31087-A37. The numbers you were looking at are the actual numbers assigne to the connectors in the wiring diagram not the part numbers. And a side note the part number X41087-AM-X31087-A37 is not a Chrysler part number but the vendor's part number. These can be tough to track down without knowing who the vendor is.
shaftman_05
Southern Michigan
Sale Price: $29.46
it looks like jeep guy used this cable and spliced it into his own custom harness. FYI the part I listed hay a y connection going to the locking tailgate mech, it may be avail without it but you should be able to hook it into your own fabbed cable.
FYI the part numbers for the two connectors are the same, X41087-AM-X31087-A37,
Nice find. I hadn't been able to put both parts in hand yet. That clears that issue up!
biwanow
Canada
Cummins 6.7
I emailed customtronix, and they said they could get me that harness for the oem cargo for $80 plus the software. I dont think they know I have their jailbreak and harness already, they probably were thinking of adding it stock. Anyways, shaftman if you get something worked out, could you post some instructions/photos of how you did it?
shaftman_05
Southern Michigan
Yup. I am in the works now, once I get it how I want it (very picky) I will post the info.
cptwing
6.4l Hemi
I found a 2014 with the CHMSL installed from the factory at a local dealer. I have given the Vin to my local parts guy and he is looking for me, crossing my fingers. Any of you guys try that or do you know and have a good relationship with a parts guy?
New 2014 Ram 3500 Laramie For Sale | Putnam CT
VIN: 3C63R3EL8EG171869
shaftman_05
Southern Michigan
I have access to all this stuff at work. I will try when I get there tonight.
R4z0r
Cam swap
I don't mean to highjack the thread but I couldn't seem to find a confirmation if this is a solution to my issue.
I have both the factory cargo and backup cam stock on my Ram 2500, What i'd like to do is simply have all of the cameras display on the 8.4an. Also possibly add a front camera.
If this is indeed possible, what would i need to get from these guys?
Any help would be appreciated, thank you.
