WHOA! Get Your Glass in order with this KILLER COMBO!
TUESDAY 10/7 - No one likes to clean glass, but that's probably because until recently they hadn¹t used the SCG Professional Ultra-Clear® Glass Kit. This collection of products is designed to make glass invisible and cleanup a breeze so you can get back to enjoying your vehicle.
Starting with SCG Professional Clarifying Glass Cleaner and the specially designed microfiber glass towels, remove bug guts dirt, dust, and smudges. (For extremely rough or dirty glass follow up with SCG Pro Detailing Clay). The dye free formula is streak free and prepares your glass to be protected by our Clarifying Glass Sealant, a highly concentrated, optically clear polymer than provides lasting protection for your glass. In addition to leaving your glass slick it enhances optical clarity by filling minor scratches and increasing visibility.
The simple spray on application is fast and easy with the included microfiber applicators, simply spray onto the glass to be treated, spread evenly, then buff away the residues with a clean microfiber glass towel. Each application will withstand hundreds of miles of wet weather driving and provide a clearer, safer, higher visibility glass surface when you slide in behind the wheel.
Stop fussing with inferior glass systems. Step up to Professional level solutions with SCG Pro!
DON'T FORGET TO ENTER YOUR FORUM CODE, "RAM", FOR AN EXTRA 10% OFF!
