The weight of a trailer's tongue plays a critical and decisive role in how your truck responds when it’s rolling down the road. If gauging your trailer's tongue weight is a hassle for you, Weigh Safe Ball Mounts are worth your attention. They are known as the worlds first ball mounts with built-in scale to measure tongue weight. Simply hook-up your trailer to the Weigh Safe ball mount - the weight of your trailer will push down on the hitch ball, which in turn pushes down on an internal hydraulic piston that sits on a bed of oil. When the piston drops into the oil, the pressure reading is sent out to the scale.
Available in 4", 6", 8", and 10" drops you can choose the one that best suits your trailer. You also have the ability to pick from a 2" or 2.5" shaft. Each ball mount comes with both a 2" and 2-5/16" stainless steel balls. All components are built of 6061T6 aluminum billet, also they are rust and corrosion resistant.
Take towing to the next level! Purchase any Weigh Safe products and GET up to 15% OFF. Do not hesitate and make your purchase right now. Prices are already reduced. Hurry up, this offer expires on December 19, 2016.
Weigh Safe® - Adjustable Ball Mount
