carid
For a reason, side steps are listed among the top-5 must have accessories every truck owner should equip his work horse with. If your Dodge Ram came stepless from factory or you simply don't like the way the OE set look or function, we've hand picked two options engineered by Addictive Desert Designs to help you upgrade your truck in the way you need it. These easy-to-install add-ons will not only add some bonus points to the protection and functionality of your Ram, but will noticeably simplify the process of getting into the cabin as well. Both side step sets are designed to provide you with a wide stepping surface for the entire length of the board and can be attached directly to your factory mounting location. These side steps come with all necessary hardware.
* click on the pictures below to find prices and other details on Addictive Desert Designs side steps at CARiD;
ADD® S50179NA01NA - Stealth Side Steps
Fit: 2015 Ram 1500 4 Door Models Only;
Weight: 105 lb (48 kg)
Dimensions: 90 x 21 x 16 in (229 x 53 x 41 cm)
Availability: Manufactured;
Notes: Mounting Kit Included.
ADD® S50389NA01NA - Lite Black Side Steps
Weight: 95 lb (43 kg);
Dimensions: 90 x 21 x 16 in (229 x 53 x 41 cm);
Follow the link to browse through our wide selection of Off-Road Accessories by Addictive Desert Designs:
Feel free to contact me if your have any questions or need a price quote. Special prices are available for all RAMforum members!
