Handy Torxe Jump Starter for your Dodge Ram
carid
Cranbury, NJ
Hemi 6.1
If you've ever been stranded with a dead battery on your truck or needed to fire up a lawn mower with a completely drained battery, make sure to check our compact and powerful Jump Starter by Torxe. It is available in 2 versions with different capabilities JS400 (14000mAh) and JS750 (21000mAh), engineered to charge the equipment you need in the most efficient way possible.
Torxe® - Compact 12V Car Jump Starter with Air Compressor at CARiD
Notes:
* 200A Starting Current, 14000 mAh Capacity - Recommended for Gas Engines up to 5.8L, Diesel Engines up to 3.0L;
** 400A Starting Current, 21000 mAh Capacity - Recommended for Gas Engines up to 8.0L and Diesel Engines up to 6.0L.;
With Torxe power banks you will be able to charge almost everything you might think of, from your smartphone to the ATV. Each system comes with various charging cables, jumper cables and 8 charging port adapters. What is more, thanks to the portable compressor your deflated tires won't stay in that condition for long.
Check out the video overview of Torxe Jump Starter presented by our Product Expert Greg to learn more about these power banks:
https://www.youtube.com/watch?v=mSW5itjKrgc
Handy and compact Jump Starter by Torxe will keep your truck on the go no matter what. See more details on these power banks at CARiD.
Click on the link below to find more Auto Parts & Accessories manufactured by Torxe:
https://www.carid.com/torxe/
