Looking forward to the end results! 8 inch bds with 1" spacer dual fox shock hoops dual steering stabilizer, rear traction bar. All powder coated. 22x12 on 37's
Why are you doing dual shocks? It's going to ride like the suspension is made of high PSI concrete (i.e. not well). That's very not recommended by the expert builders for Rams...
I will be sure to get before and after pics !! as far as the dual shock add on the shop is talking with bds, were going to eliminate the shock in the spring and install limiting strap inside mainly going for the dual shock look but still looking into it
