2014 2500 Leveling
SlightlyTweaked
Sullivan County NY
5.7 HEMI VVT
You can use 5100 shocks, you can not use 5100 adjustable struts
Thuren will be releasing springs for the new front ends soon
More then a spacer but will ride much better
Thuren Fabrication 2013+ Leveling Coils *PREORDER*
I was just gonna email them and ask if a kit would be available soon. Thanks for the info. i will still need +2.5" travel shocks for these springs correct? Also what other front end adjustments would I need to make? I've only ever installed body lift kits or leaf kits on older trucks (78-85)
Tinsey
So Cal
6.7 Diesel
Has anyone found a good quality front leveling kit for 2014 2500 diesel 4x4 yet? I would prefer new springs and shocks complete with adjustable track bar.
KTM
San Diego
4 Wheel Parts say they have a 2" Procomp available but its not shown on their website. Went into the store and they called the Pro Comp guys and were told the 2" spacer is available!!! Hmmmmm, I might just give it a shot without changing shocks and wait for the Carli system to come out.
It would be nice to get it leveled and put the 35"s on there with new wheels.
I'll keep you posted.
KTM
San Diego
Well, i just got off the phone with the guys at 4 Wheel Parts, they answered all my same questions AGAIN. I think he is tired of me questioning their kit, said its new and not on the web site yet. Also, confirmed that they use the factory coil isolator and is made for the radius arm configuration.
I am scheduled for a install next Thursday.
Pic's to follow........
SlightlyTweaked
Sullivan County NY
5.7 HEMI VVT
cjcoffroad has the2014 Ram 2500 3" Carli leveling coils for $299, and Bilstein 5100's on all 4 corners for $340. I have been emailing him bak and forth all week, probabaly gonna pull trigger next week.
shocking14u
2003 Ram 2500
Diesel
What part numbers are you guys running for the 5100's on the 2014 models with 2" - 2.5" of lift?
shocking14u
2003 Ram 2500
Diesel
I understand that, 5100 are not just related to coil overs, they are used in conventional shock applications also. Someone previously in the thread had mentioned the new Thurein kit with 5100's. I am looking to do a 2" spacer with 5100's and I cant find any info on them yet for the 2014's. So I am curious to what is available out there.
KTM
San Diego
Just got my truck back from 4 Wheel Parts.
Photos are in my Album.
Procomp 2" lvl kit which also has a bracket that lifts the bottom shock mount so you don't lose downward travel. This kit will work for a year or so until some real lift kits come out (Carli or KORE). Tires are 35" TOYO AT II, wheels are 18x9 FUEL Boost -5.
Only6
Had Bilstein on the phone yesterday... rep said the only ones for 2014 2500 CTD front are # 24-239448 for 2-2.5 lift, and rear # 24-239455 with stock to 1". Obviously I mentioned others are running the older part #'s, which he was quick to say that the ones listed are the only ones that should be used.
SlightlyTweaked
Sullivan County NY
5.7 HEMI VVT
Get ahold of CJC Offroad. They have the Thuren 3" front lift springs for the 2014 2500 CTD and shocks to go with them. I was going to order them before I realized the springs weren't available for the HEMI
