2017 3/4-Ton Premium Truck Challenge
SouthTexan
408 CTD
All top of the line 3/4 ton diesel trucks. Coming in May!
The contenders:
Chevy 2500 LTZ Duramax
Ford F-250 King Ranch
Titan XD Platinum Reserve
Ram 2500 Laramie Longhorn
My take.... When it comes to stock 0-60, fastest up the hill, and other acceleration tests, the Ram 2500 Cummins will no doubt come in behind the more powerful Duramax and Powerstroke engines. I see the Ram Cummins winning the mileage tests ever the other two, but not over the Nissan Cummins. Too bad they don't have a dependability test. The Ram Cummins would easily win that one hands down.
Update: 2017 3/4-Ton Premium Truck Challenge Video: What the Judges Thought
drittal
E. Montana
I was a little surprised by the outcome of the 3500 DRW challenge with the F350 being slowest.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
The titan XD is not a 3/4 ton truck. It's a heavy half. A friend has one and it only has 2039 lbs of payload and that's with the V8 Gas.
It's a nice truck for what it is, but it's no where in the same league as my ram is in terms of size of suspension components, steering components, etc.
SouthTexan
SouthTexan
408 CTD
The Titan XD is a 3/4 ton per its specs. What qualifies a truck as a 3/4 ton if it has a GVWR within the class 2B weight limits of 8,501-10,000 lbs. The Titan XD crew cab has an 8,990 lbs GVWR which is just 10 lbs less than the 9,000 lbs GVWR of the Ram 2500 with a 5.7L. So saying that an XD is not a 3/4 ton would be saying that a Ram 2500 5.7L is not a 3/4 ton either.
coobie
S.Michigan
2022 Ram 1500 big horn
I sure hope DANNO is one of the judges :flipthebird:
Ratket
Arizona-
We will see how the nissans hold up- The motor is obviously sound.. but we will see how the rest of the truck does
spoon059
Just north of Washington DC
6.7 CTD
You are 100% right, but I understand what he meant. The Nissan with the diesel has a very low payload, because of the weight of the truck and the lower GVWR. The 5.7 Hemi is substantially lighter than the Cummins in the Nissan.
Its all semantics anyway. It will be interesting to see how they all compare.
stoney
Ontario
2015 | 2500 SLT CC
6.4L w/ 4:10
Have you heard of the engine replacements due to some turbo problems?
Talking to guy that had two of these, both needed new engines for the same turbo issue, apparently there was quite a few of these out there but did not seem all that publicized, and he also commented on some electrical gremlins with both of these trucks.....so he decided to get out of the Nissan for a few years until things got better.
Otherwise, he did love the truck.
SouthTexan
SouthTexan
408 CTD
Well, it it was exactly what I thought. The new and improved Duramax and Powerstroke engines out accelerated the ole' less powerful Cummins in just about every challenge while the Cummins got better fuel mileage both loaded and unloaded. That new rev happy short stroke Duramax must be a screamer and would probably what I would buy if I wanted to tow something fast. I would rather have the better fuel economy and dependability with the Cummins though which is why I would go that route again if I had the chance to choose.
Although the Duramax does not have as much of an overly intrusive torque management in the first few gears like the Ram and Ford's have. I remember watching a video where a tuner from Calibrated Power said that EFI software showed torque management on the Ram is the worst, with the Ford second, and GM has the least.
I am kind of surprised that that the Cummins beat the Powerstroke in the 1.25 mile Davis damn towing 10k and even bested the smaller 5.0L Cummins in towing mpg.
3/4-Ton Premium Truck for 2017 Results
drittal
E. Montana
I think there must be something, tuning or nanny, holding back the PSD as the Ram bested it in the 3500 Ike test.
SouthTexan
SouthTexan
408 CTD
Yep, I would have to agree. Looking at the dyno numbers, the ford should have mopped the floor with the Ram. Considering that the Ram had the tallest gearing and lowest power numbers, it really didn't do bad at all. I wonder how things would be if the Ram and Ford would have had 3.73s like the GM did.
drittal
E. Montana
Seems like the power wars are now just a marketing gimmick as the levels are too high for the rest of the powertrain
wyo2track
western Wyoming
2014 RAM 2500
6.4L Hemi w/ 4.10's
Some take aways from what I see...
Agreed...the super duty is under a tight rein.
The 3.42's in the RAM 6.7 get criticized all the time, but, test after test with 3/4 ton load classes, they continue to compliment the CTD nicely. :waytogo: IF....If Ram would just eliminate 30-50% of the torque management they have on these trucks it would go a long ways.
Assuming PUTC ran the same 111 mile loop as they did with the 3/4 ton work truck (gas trucks) the 2017 CTD is a solid 3.5 mpg better than a 6.4 Hemi with 4.10's. The Ford and Chevy diesels only did 2.5 mpg better than their gas counterparts with 4.10's.
The Titan XD.... don't really know what to say, but it would appear the gooseneck hitch is really more of a marketing ploy than anything. Figuring a 15% hitch weight of the 10K trailer put it 300# over its payload...without anyone in the cab...without any other gear...and the truck just about weighs as much as the 2500's...and it doesn't have much more payload capacity than a RAM 1500 with the Ecodiesel.... Ooooffff.. :****sweak:
All these trucks are damn expensive!!
