Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
2500 Snow plow prep group
This is a discussion on 2500 Snow plow prep group within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
Anyone know definitively if the snow plow prep group contains any upgrades to the suspension, particularly for the '16+ trucks? ...
Like Tree28Likes
Reply
Old 02-15-2017, 10:44 AM   #1 (permalink)
mohemipar's Avatar
Ram Year: 2013
Engine: 5.7 Hemi
Default 2500 Snow plow prep group
Anyone know definitively if the snow plow prep group contains any upgrades to the suspension, particularly for the '16+ trucks? Ive looked around and found no real proof. I did find that the snow chief group does. Just trying to determine why one would order the prep group when you can get skid plates and hooks in other packages that also include more valuable options.
Sponsored Ad
Register to remove this ad.
mohemipar is offline   Reply With Quote
Old 02-15-2017, 11:13 AM   #2 (permalink)
Ram Year: 2015
Engine: Hemi 6.4
Default
I have the SP prep group on my 2015, and it only listed the high output alternator and skid plates. The Snow Chief package appears to contain more substantial upgrades, although options included also vary by model.
Ram Trucks Makes the Most of Snow, Performs Winter Testing | Off-Road.com Blog
__________________
2015 Ram 2500 CCSB Laramie, 6.4, 4.10's, ARH LT Headers, MF Cat-back, HF 93 tune, Edge 2600 converter, Moe's 87mm TB, Traxda leveling kit, Thuren adj. track bar, Centerline Grizzly 20x8.5 rims, Cooper S/T Maxx 35's.
2012 Mustang GT, 1986 Mustang SVO, 2003 CBR 954, 2014 MDX
theviking is offline   Reply With Quote
Old 02-15-2017, 11:39 AM   #3 (permalink)
SHOOT2KILL's Avatar
Ram Year: 2015
Engine: 6.4
Default
The link you provided is laughable...FCA snowplow testing in Houghton,MI...I have been thru there dozens of times during winter months riding my sleds. The snow comes down there like pillow feathers, not a good place to test your plow capabilities. Head further south and plow some real snow that at times has the consistency of wet cement...I spent close to $60k on this 2500 Ram, A new Western snowplow, and a new salt speader. It's the worst plow truck I have ever owned. Almost 30 years in the Comm plow/salt biz...Just my opinion...........
SHOOT2KILL is offline   Reply With Quote
Old 02-15-2017, 11:42 AM   #4 (permalink)
Sandbox's Avatar
Ram Year: 2017
Engine: 6.4 HEMI
Default
My window Sticker list the following for the Snow Chief Group:
  • Transfer Case Skid Plate
  • 220-Amp Alternator
  • Anti-Spin Diff rear Axle
  • Instrument Panel Mounted Auxiliary Switches
  • Clearance Lamps
  • LT275/70R18E On/Off Road Tires
__________________
2017 2500 Laramie 6.4 Crew Cab | 4.10s | Ram All-Weather Mats | DZ Tailgate Assist | Otherwise Stock
Sandbox is offline   Reply With Quote
Old 02-15-2017, 12:03 PM   #5 (permalink)
Ram Year: 2015
Engine: Hemi 6.4
Default
What makes it a bad plow truck?
__________________
Old 02-15-2017, 12:34 PM   #6 (permalink)
SHOOT2KILL's Avatar
Ram Year: 2015
Engine: 6.4
Default
Absolutely the worst factory tires for snowplowing. Especially since these tires are actually an upgraded tire just for the Snow Chief pkg. The sipe line goes around the circumference of the tire, not across the width of the tire to shed the snow.
The 3.73 gear is NOT a snowplow gear, unless you are plowing pillow feathers. The FCA engineers should include the 4.10 gear as an additional piece within their Snow Chief pkg...It's only $50.00 more
The shift points in the tranny do not work in conjunction with the what is required to plow long runs of real snow. The shift from 1st to 2nd is again laughable from a plowing standpoint.
Poor tires...Wrong gear for plowing...Shitty trans shift point for plowing...You should see the dashboard idiot lights lite up like a fireworks display, when I'm making a long plow run of wet snow, and the truck cant handle it due to nothing working together
DO NOT INVEST IN A RAM TRUCK FOR H.D. COMMERCIAL SNOWPLOWING...THIS IS MY PROFESSIONAL OPINION AFTER ALMOST 30 YEARS IN THE BIZ AND A FEW MILLION DOLLARS OF REVENUE GENERATED...
Old 02-15-2017, 12:44 PM   #7 (permalink)
Ram Year: 2015
Engine: Hemi 6.4
Default
I can't tell if you feel strongly about this not being a good plow truck:P
No doubt the tires are horrible, but that's easily corrected. Also no doubt the gearing leaves something to be desired, a 4.44 or 4.56 option would have been awesome. Did you ever consider running a HF tune were he adjusts the shift points? Understand warranty an cost are concerns but it definitely makes a big difference overall.
__________________
Old 02-15-2017, 12:54 PM   #8 (permalink)
Ram Year: 2016 Power Wagon
Engine: 6.4
Default
Just use 4low, problem solved. Or buy a ford.
Danno is offline   Reply With Quote
Old 02-15-2017, 01:06 PM   #9 (permalink)
SHOOT2KILL's Avatar
Ram Year: 2015
Engine: 6.4
Default
I have never had to do the things you mentioned on any of the dozen or so plow trucks ive had over the years. All of those other trucks all came with 4.10 gears included in the plow prep pkg, even the early diesels I had. Factory tires were designed for plowing. And NONE had the shitty 1-2 shift...I did replace the shitty TRANSJUNK tires with an ultra aggressive thread KANATI MUD HOG tires ($765.00) that realistically should NOT have to happen either...NO...I will not jeopardize the warrenty with a tune, nor will I spend the coin to do a gear swap, that should have been included in the S.C. pkg...AGAIN...Overall the truck as it came from the factory is a P.O.S. for H.D. Commercial Plowing ....IMO...
Old 02-15-2017, 01:10 PM   #10 (permalink)
SHOOT2KILL's Avatar
Ram Year: 2015
Engine: 6.4
Default
I had an open mind when I was shopping this truck...Buying a FORD would have been no problem for me....UNTIL...I was told by the dealer that since I was paying CASH for the truck, the price would be $1500.00 MORE...LOOOL...FUCK YOU FORD...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
17 2500 with level kit and snow plow? Mr2500HDMan Heavy Duty 10 02-12-2017 12:20 PM
5th wheel tow prep group question (rambox or group) cc rider Towing & Hauling 9 02-10-2015 11:08 AM
snow plow prep? mowin General Discussions 7 03-10-2014 10:17 AM
**** Snow plow **** dodge15004x45.9 Wanted 0 07-09-2010 11:45 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
