bighorn2500
- Feb 8, 2015
- 45
- 13
- 2015 2500 ram bighorn
- 6.4 hemi
If 35s will fit a 14 or 15 without rubbing on stock wheels. Will 37s fit with a 2 inch level.
Yes it does. It's a pain in the ****. You have to take the inner fender cover off and then you will have just enough room to get an open end wrench in there. The 14 2500 is the same way. I done the passenger side in like 20 minutes. And the driver side took about 1½ hours. And a lot of skin off my knuckles.I like the stuffed look... The whole point of tires is more ground clearance, if you can get it without lifting the rest of the truck and CG why not? But I do like the look of a 6" lift, so I see both ways.
I'm off to Sears to buy a new fu@&!?$ floor Jack! Mine just **** the bed... Fluid everywhere... Yay, now I get to clean before I lift
Sorry. I quoted you on the wrong post. It will fit. Lol. See my last post. Sorry.So apparently the rough country 2.5" level kit doesn't fit a '15.
My driver side coil bucket isnt open on top. It covered over by frame steel and the abs pump is on top of that. The flag nut that goes up in there to hold the spacer has no where to go. FML...
It's all good... Lol
Ok here's how it went down. This is hard to explain if you haven't installed this before. The RC level kit is well built, except for the flag nuts that hold the level blocks to the coil buckets. I finally got it all to work but it won't be staying on the truck long.
The passenger side coil bucket is open on top, probly a 3.5" diameter hole, that was punched in the steel so the top edge is rolled down. There's tons of room to get on top of it and put the flag nut in. The instructions say to put it in from the bottom where the spring would be but you can just drop it in from the top. The way it seats in there (and what I'm really unhappy about) is the flag nut is pulled into the hole by the bolt that goes up thru the leveling puck. The hole in the bucket is conical and the nut plate is just slightly larger than the bottom of the hole. So if that nut plate bends in any way it'll fall through the hole (likely? Not really but still a **** poor design) plus the nut that welded to the plate to make it a 'flag' nut is a cheap grade 5 easily stripped nut.
So here's the really fun part. The drivers side nut plate will go in the coil bucket, but only from the bottom. The hole is still conical shaped just like the pass side, so the flag nut is pulled into the hole. Getting it in there requires you to put it in at an angle sliding it into the one and only little gap that's not welded over by the abs support bracket (part of the frame), and then sliding it level into the hole so it can't fall out (which it does a few times until you get both edges seated in the hole).
Other than it goes together easily, I had the job done in2 hours by myself with 2 floor jacks. I've instlled a few RC lifts and these were the worst instructions I've ever seen from them. I didn't really use them but the oictures of the parts don't match what you're installing which is what initially threw me into thinking it wouldn't work. They don't tell you the flag nuts are designed to be pulled into the hole. The pics show a long nut plate the would just sit over the frame and clamp the lift puck down.
All is well though, after a short drive to settle the springs there is even more room for the 37's than I initially planned. I'll get pics up tomorrow after the alignment, still waiting on wheels though.
H
And I'm sorry if that was a confusing write up, if you're curious enough get on RC's website and pull up the instructions for the lift. You'll see what I'm talking about.
