Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
5.7 hemi milage
This is a discussion on 5.7 hemi milage within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
I drive 67 - 70 on the highway and do a bit better. Your mileage sounds about right for driving ...
Like Tree2Likes
Reply
Old 01-08-2017, 06:44 PM   #11 (permalink)
Ram Year: 2014 Ram 2500 SLT CCSB
Engine: Hemi 5.7
Default
I drive 67 - 70 on the highway and do a bit better. Your mileage sounds about right for driving that speed.
Sponsored Ad
Register to remove this ad.
billa9b0ng is offline   Reply With Quote
Old 01-08-2017, 07:22 PM   #12 (permalink)
Ram Year: 2014
Engine: Hemi 6.4L
Default
I lose 1 mpg for every 5 mph over 65. It's a big brick, and it takes a lot of energy to push it through the air.
__________________
2014 RAM 2500 Laramie Mega Cab 4x4 Maximum Steel 4.10s Auto Highbeams Auto wipers
Undercover Flex tonneau cover
NewBlackDak is offline   Reply With Quote
Old 01-09-2017, 08:36 PM   #13 (permalink)
Ram Year: 2014 2500 4x4
Engine: 5.7
Default
Thanks much for the replies. I was incorrect in the rpm. It's closer to 2000. I did get a little better coming home from my trip over the weekend but still only about 11.5. Again this seems normal so I'll just deal with it. Just was concerned something was wrong but it seems ok. Thanks all. Hoping I can enjoy this truck.
hextall is offline   Reply With Quote
Old 01-09-2017, 11:15 PM   #14 (permalink)
Ram Year: 2016 2500 regular cab
Engine: 5.7
Default
thats about exactly what i average 11.3 to 12
tnt2671 is offline   Reply With Quote
Old 01-10-2017, 02:09 AM   #15 (permalink)
Ram Year: 2017 2500 Tradesman
Engine: 6.4L Hemi
Default
What I've learned about HD MPG's so far:
62mph is the magic speed.
A Magnaflo muffler will get you +1-2 mpgs. K&N filter maybe something, CAI maybe +1.
Drive like grandma.
MPG's is worse the first 10,000 miles. It seems to get better at 500 and then at 3-4000, and then at 8-10,000. (I always wondered if the computer has a break in protocol?)
Bigger tires or a leveling kit or hauling stuff makes it go down.
No wind, 10,000+ miles, freeway with cruise at 62mph, unloaded, no traffic, flat land, 89 oct good gas, should get 16+ mpg.
__________________
2017 Ram 2500 Tradesman 6.4L Hemi, Off Road Package, 4.10 anti-spin Dif, BW 44-47 T-case
HS-LD is offline   Reply With Quote
Old 01-10-2017, 10:04 AM   #16 (permalink)
68PowerWagon's Avatar
Ram Year: 2016 2500 Outdoorsman
Engine: 6.4
Default
Originally Posted by MN-Ram View Post
Do you have a tonneau cover or topper on your truck yet? They usually help a little. Also, slowing down to 67-70mph will help. I've my truck seems to have a fuel leak above 70mph (j/k). But my mileage is a lot better under 70mph. That goes for my current 6.4L Hemi as well as my 1500 with the 5.7L Hemi.
I've never tuned a gasser, but the problem with the tuner on my old Cummins was that it was way too fun to drive. I was never light on the throttle, so I actually saw lower MPG's after the tune.
If you just got the truck, and live in a cold climate, wait for the summer gas blends. You will see a little better mileage then.
Yea my 6.4 took a major nose dive when the winter blend came out. Went from about 16-17mpg to 9-10mpg.
68PowerWagon is offline   Reply With Quote
Old 01-10-2017, 04:13 PM   #17 (permalink)
Ram Year: 2014
Engine: Hemi 6.4L
Default
Mine does too. Make lots of sense. We want to reduce emissions, so we'll make them burn 30% more fuel.
__________________
Old 01-12-2017, 09:59 AM   #18 (permalink)
zogg's Avatar
Ram Year: 2016 2500 HD Crew Cab Hemi 4x4
Engine: Hemi 6.4
Default
I had a 2013 ram 2500 4x4 with the 5.7. Around town I got about 12-13 mpg, but on the hi way it was much better. With 25,000 miles on the truck we went from Illinois to Arizona unloaded and drove between 65 and 75 mph for the whole trip. We consistently got 18-19 mpg on 87 octane.
We bought a new fifth wheel and traded for a 2016 6.4 4x4.....what a disappointment in mpg compared to the 5.7......if I get 15 hi way I'm surprised. Ugh.
__________________
2017 Ram 1500 Quad Cab
5.7L Hemi, 4x4
[B][I][COLOR="Orange"]
zogg is offline   Reply With Quote
Old 01-12-2017, 10:09 AM   #19 (permalink)
Ram Year: 2015
Engine: Hemi 5.7
Default
Thank you, farm subsidies! I have a friend who farms about 2000 acres of corn and soybeans, and he'd like nothing better than to see the subsidies done away with. It impacts a *lot* more than the corn market - everything from fertilizers to beef prices get screwed up (not to mention the deleterious effect on our vehicles).
es
__________________
2017 Chevrolet SS
2015 RAM 2500 Tradesman 4x4
2012 Volkswagen Routan SEL
1963 Volkswagen Type I
1962 Volkswagen Sunroof Type I
stembridge is offline   Reply With Quote
Old 01-12-2017, 12:37 PM   #20 (permalink)
SouthTexan's Avatar
Ram Year: 2014
Engine: 408 CTD
Default
For gasoline, it is summer blend fuels that have additives to help the environment by lowering its RVP making it less volatile at higher temperatures, not winter. Summer fuel has about a 2% higher energy content due to these additives which is one of the many reasons why you get better fuel mileage in the summer. Winter fuel does not have these additives so it has a higher RVP which increases it's volatility so it can be easily burned in colder temperatures. You would have a lot harder time starting a vehicle with summer fuel on a very cold day than you would with winter fuel. It would also run rough.
There are other things that decrease your mileage during the winter as well like lower tire pressure and the air being more dense. For every 10 F the outside air drops, your tire psi will drop about 1 psi. So if it was 35 psi at 100 F, then it is 25 psi at 0 F. Colder air is also more dense than warm air which means you have to apply more load on your engine in order to push through it. The research we did at Cummins showed a 2% increase in aerodynamic drag for every 10 F decrease in temp.
Also, for gasoline engines, colder more dense air will cause the engine to burn more fuel to stay at the optimum 14.7:1 stoichiometric air/fuel ratio. Basically 14.7 air to 1 fuel. Gasoline engines have to stay around this ratio at all times in order to run correctly and not damage the engine. Since colder air is more dense, there is more of it in a given space. Therefore the engine reads this from the MAF sensor and adds more fuel to compensate for that increased air density. If it didn't add more fuel then it will run lean which damages gasoline engines.
This is why intakes generally hurt fuel economy on newer gasoline engines since the MAF sensor will tell the ECM to add more fuel for any extra air added. This is not the case for diesels since they run lean just about all the time so intakes generally make them more efficient. Under load diesels run about 16:1 and at around 140:1 at idle.
2015HD and Cmsharp like this.
__________________
2014 Ram 2500 Crew Cab Laramie 6.7L CTD 68RFE 3.42
EFIBYRYAN - AFE HD Momentum Intake - Flow-Pro 5" Turbo-back w/muffler - Thuren 2" kit w/ Track Bar
SouthTexan is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bad Gas Milage Brady18 Engine & Performance 22 04-13-2015 03:30 PM
Fuel milage cardboard Engine & Performance 32 03-07-2015 10:30 PM
real world 6.4L hemi gas milage sandawilliams Engine & Performance 5 07-08-2014 10:02 AM
engine and milage? 1badass1500 Engine & Performance 11 02-27-2014 11:43 PM
engine and milage? 1badass1500 Engine & Performance 3 02-26-2014 11:06 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
