In reply to rivers question on gear change, Yes, I did have my dealer re-gear my Ram at about the 11k mileage. I am very satisfied with the work as well as the change for the better on general drivabilty as well as towing. I would ask though, what is your intended use for the truck. Also, where do you plan on towing? Truly, knowing what I do now and having towed for over 25k of the 44k miles I have on the truck, can honestly say if towing near the max weight, and also using it pretty much as a dedicated tow vehicle, would honestly consider the 4.88 gearing if it was available. For everyday driving as well as towing, I feel the 4.56 is about as good as it gets with the 66RFE Trans. Mileage in town is about the same. Mileage on the hi way depends on the elevation. Here in the Rockies with most of the daily driving in the 4,5,6k and over elevations, it is better. Still with that low of gearing, the engine tacks out at 2200 rpm at 80 in 6th. That is just where the 6.4 is starting to get happy. Also, the MDS is now working as well as possible in the higher elevations.
