Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
6.4 Hemi Gear Swap
This is a discussion on 6.4 Hemi Gear Swap within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
This is just a fleeting thought at this point but I'm curious what is even available. In searching the forum ...
Like Tree62Likes
Reply
Old 12-09-2015, 10:54 PM   #1 (permalink)
Ram Year: 2014
Engine: Hemi 6.4
Default 6.4 Hemi Gear Swap
This is just a fleeting thought at this point but I'm curious what is even available. In searching the forum all I can find is info on 1500 trucks.
I have a 2500 gas with the 3.73s and I know the 4.10s were an option. Are there 4.30s and/or 4.56s (or something else?) available for my truck? It's a 4X4 so I'll need both front and rear.
Sponsored Ad
Register to remove this ad.
mtofell is offline   Reply With Quote
Old 12-09-2015, 11:03 PM   #2 (permalink)
brandonjansen's Avatar
Ram Year: 2012 Ram 3500 Laramie Limited
Engine: 6.7 Cummins - Tuned and Deleted
Default
4.10's or 4.56's yes. 4.30's are for the rear diff but next to impossible to find for the front diff.
You'll need ring and pinion kits and pinion install kits at a minimum. Likely pinion bears as well as they are generally destroyed trying to remove them from the stock pinion.
What exactly is your reasoning for wanting lower gears? Planning to be running 37's?
brandonjansen is offline   Reply With Quote
Old 12-09-2015, 11:04 PM   #3 (permalink)
Ram Year: 2015
Engine: CTD
Default
Somebody on here has already done the swap but can't remember who. I'm sure they will chime in soon.
__________________
2015 Mega 2500 CTD | Access Lorado cover | Recon Smoke Taillights/3rd brake light | Rough Country Level | Fuel Turbo 20x10-19 | Fuel Gripper MT 35s
spiG is offline   Reply With Quote
Old 12-09-2015, 11:54 PM   #4 (permalink)
Ratket's Avatar
Ram Year: 2014 2500
Engine: Hemi 6.4
Default
Karl45- I believe is his name, he had a dealer install 456- and twilliams had a shop he knows install his 456. Karl"s are covered under his warranty since he had the dealer do it, but it cost him almost 3X what twilliams cost to do his. This is a mod I really want to do. I think it is the perfect gear match for these trucks with a 35" tire. or even if u stay stock size and tow regularly.
__________________
2014 Ram 2500 mega cab Big Horn 6.4 4x4 3.73's Factory 20's wrapped in a 33" maximum steel/ Factory cab length running boards/ UnderCover Flex Tonneau cover/de badged/tinted over factory tint.
Ratket is offline   Reply With Quote
Old 12-10-2015, 12:16 AM   #5 (permalink)
Default
..... I have.... Mine's a 2012 3500 Cummins however the front differential is the same between the two (9.25 AAM) and the rear differential is very similar. 10.5" AAM on the Hemi 2500's VS an 11.5" AAM in my Cummins. The design is the same between the two.
Old 12-10-2015, 01:02 AM   #6 (permalink)
Ram Year: 2014
Engine: Hemi 6.4
Default
No change in tire size.... just looking at towing heavy. I wish I'd have held out for the 4.10s but they are/were hard to find so I just took what I could get. The change to 4.10 gives another 3000# in towing capacity. If swapping to 4.10 is easiest/cheapest I'd likely go that route. I was just thinking as long as I were doing it I might as well see if going up a couple steps made sense. Also, gas is on my company so MPGs really don't matter to me.... within some reason.
Realistically, I'm not looking at towing super heavy and I'll most likely just stick with what I have. I'm somewhat kicking myself for not just getting a diesel but that's just life. I'm not minding having the extra 6K in my pocket now that I would have spent. Overall, I love the Hemi and am pleased with the way it tows. I'm just a weekend RVer and 95% of my miles are spent with no trailer so it's not a huge deal.
If I could jump up to the 4.10s for less than a couple thousand dollars and keep my warranty all intact (so, work done at the dealer I suppose) I'd probably go for it. Otherwise, it's not like I'm in terrible shape with the truck I have.
Old 12-10-2015, 01:05 AM   #7 (permalink)
Ratket's Avatar
Ram Year: 2014 2500
Engine: Hemi 6.4
Default
How quick is that cummins to smoke those 37"s through that 456 gear set?
__________________
Old 12-10-2015, 01:07 AM   #8 (permalink)
Ratket's Avatar
Ram Year: 2014 2500
Engine: Hemi 6.4
Default
456"s at a shop is like 1600$ I think..well worth it, u should get better mileage on the why as mds will activate easier.
__________________
Old 12-10-2015, 01:22 AM   #9 (permalink)
Default
If you're sticking with stock tires I wouldn't go any lower than 4.10's. That will already be pretty low for those tires. If you ever plan on going to 35's or something then 4.56's may be a good option.
The price to have 4.10's or 4.56's installed will pretty much be the same. The parts will be very similarly priced; it's the labor that's the expensive part. I paid just shy of $3000 for my 4.56's installed including all parts, labor, sythetic oil (which was a lot in my truck with the Mag-Hytec rear diff cover), and tax. I had a few quotes from US shops to do it as well and they were in the $2300 range I believe. So I'd say that's roughly what you're looking at if you have a shop do it. For a dealership to do it I'd imagine you're look at a lot more if they even know how to do it. Honestly I wouldn't ever have a dealership touch a differential on my truck. They're something that needs to be setup right the first time or you will chew up the gears. Having an experienced driveline shop complete the work will be worth it.
You shouldn't have any issues with warranty doing that. For one, the dealership will never even know you changed them. Two, they would have to prove the gears are the cause of the problem if something ever did happen which simply won't be the case. 4.10's will make it easier on your driveline, not harder.
For the record, even if you do change your gears your truck doesn't legally have a higher towing capacity. Any authority will still go off what the door sticker says which is what the truck is rated at with 3.73's. Sure it will tow much better and common sense would tell you that it should be able to legally tow more. But unfortunately insurance companies and a lot of authority lacks common sense. That's only applicable if you ever do get into trouble (accident) or pulled in for an inspection while towing or something.
Ridiculously quick. lol. Sometimes too quick as it breaks loose when I'm not actually wanting it too. I guess 1100 ft-lbs will do that
Very likely that he'll get slightly worse mileage with the lower gears. The higher RPM you end up turning outweighs the other benefits. I lost about 0.5 mpg going from 3.73's to 4.56's. Totally worth it though as the truck is SO much better to drive.
theviking likes this.
Old 12-10-2015, 10:52 PM   #10 (permalink)
Ram Year: 2014
Engine: Hemi 6.4
Default
Thanks everyone.... lots of great info. I'll have to see how it all works out when I get a bigger RV. I likely won't even be over what the 3.73s are rated at but generally hate maxing out anything. I can't imagine the change to 4.10s is really big enough to justify the cost but who knows. It's kind of a pisser that about 90% or more of these trucks came with the gear ratio that no one seems to want given the choice.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gear swap... boomer135 Engine & Performance 4 04-08-2015 07:34 PM
Gear swap ????? pressurepro Engine & Performance 33 02-02-2015 07:23 PM
Gear Swap 4.11:1 or 3.92:1 ? mjb Towing & Hauling 8 09-24-2013 03:44 PM
410 lsd and gear swap thestewman All Mopar Parts 3 09-09-2013 10:18 AM
4.10 Gear Swap Jerseymike All Mopar Parts 3 08-27-2013 11:17 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
