6.4 Hemi Gear Swap
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Maybe if you use parts made from Chinesium.
If the labor is 1k both axles I don't believe the gear sets are more than $500 each for the aam parts are they?
RAM_Designs
Rockwall, TX
6.4L Hemi
Gotta get the master install kits as well, the gear and pinion sets are usually around $400 depending on brand. Then you need the fluids as well. It all adds up in the end.
reloaderguy
Oregon
2016 Power Wagon
You need bearing and shim (installation) kits. You're looking at well over $1k in parts alone.
Reactions: U&A
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Ok thanks guys...i always figured it'd be around 1500/axle so it looks like that's still in the ballpark.
I remember way back getting 3.73 gears in an 86 mustang 5.0/5 speed. I think the entire job was $500 or something like that. Man those 73s made 1st gear like a creeper gear....it'd blow the tires off big time......if you really got after it (LOL)
U&A
Michigan
2016 3500 SRW
6.4 HEMI
4.88 Nitro gears, both axles
I was $2300 out the door. I used a guy on wixom lake in hope michigan.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
That is a great price man. How do you like the 88s? I think you gave one update since install. Are you still liking them? Worth the cost?
U&A
Michigan
2016 3500 SRW
6.4 HEMI
Absolutely the best modification i have ever done to a vehicle in my life. I love the 4.88’s. A part if me wishes i went to 5.13’s with my 35’s but the 4.88’s make it a completely different truck in a great way.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Cool man...thanks for the feedback. I think I'd go 4.56s with my stock tires... If i could get them for the price you paid id be tempted
What did you do with your speedo...? Can it be corrected somehow?
Reactions: U&A
Fearfact
Man I actually think mine tows decent with 373s and 35s and I pull about 15k in NH... a hell of a lot better than our v10s did or the ford 6.2s all on stock tires...I would like to swap to 456 eventually but probably won’t bother
U&A
Michigan
2016 3500 SRW
6.4 HEMI
Going from stock 33’s to 37’s will play hell on your torque converter. Do the gear swap
Fearfact
Yes I do know that lugging will be the death of this transmission and that a deeper gear set will make a substantial difference. I guess my point is more directed at the guys moving 10k or less that think they need deep gearing because these trucks aren’t capable. I have had 20k behind it (pintle trailer not goose or 5th )and no it didn’t like it much but it did a darn good job. My truck may or may not get gears depending on it I keep or upgrade, it’s hard to justify getting rid of it as I have maxcare and a very forgiving dealership but I do need something better suited for the weight/uses
U&A
Michigan
2016 3500 SRW
6.4 HEMI
Before you decide what ratio you want figuring out what rpm you want to be at in each gear at a specific speed. Then figure out what gear ratio will get you close.
I am basically 2000 rpm at:
1st gear 10mph
2nd 20mph
3rd. 30mph
4th. 40mph
5th. 50mph
6th. 70mph.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
1st gear 10mph
2nd 20mph
3rd. 30mph
4th. 40mph
5th. 50mph
6th. 70mph.
Wow that's not bad at all with that Steep of gearing to only be turning 2k at 70 mph. I'll have to play with the gear calculators. Id be fine turning 1800- 2k in 6th at 70 with my stock tires...but don't know what gear would put me there.
I know how much those 3.73s woke up an otherwise stock 5.0 mustang going from a 3.08 gear. It made it feel like a totally different vehicle. So i can only imagine what a 4.88 would feel like in my truck with stock tires. I bet i could surprise a few mustangs and cameros...at least off the line.
Ratket
Arizona-
If ur on stock tires.. they are just gonna laugh as they drive away and u are smoking those garbage tires lol
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Hahahahahahaha lol! Probably so! But who knows? I could ease into her off the line and then hammer down once I'm out 60 foot or so? Lol...just kidding....ahhhhhh i sometimes miss my late teens/early-mid 20s and all the racing i used to do.. .fun times.
