brandonjansen
- Feb 14, 2013
- 1,701
- 1,012
- Abbotsford, BC, Canada
- 2012 Ram 3500 Laramie Limited
- 6.7 Cummins - Tuned and Deleted
You could always move up in tire size From your pics, it looks like you can go a size up to 40's!!!!!
That would bring your RPM's down a bit and should work out nicely for 4.56's. AEV uses 4.30's for 40's, so the 4.56's should work perfectly for you
I can't fit 40's on my current setup unfortunately. The 37's already required some trimming on the 12 wides. However the dream is for bigger tires in the future which is part of the reason I did go to 4.56's. I'll just need to add some more lift to make that happen
