Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
6.4L Oil and MS-12633
This is a discussion on 6.4L Oil and MS-12633 within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
Id agree that most would be fine, but Im almost certain this MS-12633 has something to do with the oil ...
Like Tree20Likes
Reply
Old 01-06-2017, 10:28 AM   #21 (permalink)
Andrew09HEMI's Avatar
Ram Year: 2014
Engine: Hemi 6.4
Default
Id agree that most would be fine, but Im almost certain this MS-12633 has something to do with the oil and its state under heavy load/temp.
Hootbro likes this.
Sponsored Ad
Register to remove this ad.
Andrew09HEMI is offline   Reply With Quote
Old 01-06-2017, 10:36 AM   #22 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
One thing I want to say: After viewing 2 VOA of the SRT 0W-40 as well as more then a handful of UOA it shows to be one of weakest 0W-40 oils. It's additive package is some what weak compared to RL/M1/Castrol. It only has a excess of Tri-Nuclear Moly! Which is a plus! It has shown to shear down to a 30wt really quick!
It's nothing special! Shell really needs to spend some more time with the additive package.
Within the Hellcat/SRT forums: Many of the owners have jumped ship and have started running M1/Castrol 0W-40. Some have began running T6 5W-40.
For the normal 6.4L driver the SRT 0W-40 will serve/protect the motor well. If I was working that motor most of the time? I believe there are better options out there @ a lower cost!
Looking at both VOA 7 months ago the PUP 5W-30 actually has a more robust additive package then the SRT 0W-40 . The SRT only has more Moly!
This is only my thoughts/opinions through my own research. The SRT 0W-40 is a decent oil for your 6.4L. I just believe there are more robust oils out there.
Hootbro likes this.
__________________
2014 Bighorn SLT 1500 QC 4WD 5.7L BW44-44 8HP70 3:92s w/Anti-Slip!
Oil: 6Qts (GTL) PUP 5W-30 / 1Qt (GTL) SRT 0W-40 & 4oz ZDDP Plus w/RP Filter!
Front -8HP70/T Case- Rear: RL 75W-90 - Red Line D6 ATF - RL 75W-140/90 Mix!
Coolant: Peak Global Lifetime w/RMI-25 Air: AEM Drop In {Dry-Flow}! No CAI!
Fuel: (Shell) 89 w/6oz TCW3 or 24oz Soy Ultra / Neutra! Mileage: 24,429
SyN is offline   Reply With Quote
Old 01-06-2017, 10:47 AM   #23 (permalink)
Ram Year: 2016
Engine: 6.4L Hemi
Default
I noticed this when I was running it and draining it.
I did this before my most recent M1 fill. I had some leftover Redline 10w-40 so I did a 4/3 combo with the T6/Redline. I liked that much better than the 5/2 I did the the M1/Redline.
__________________
Granite Crystal 2016 2500 CCLB Tradesman 4x4 with +2" PW Suspension
18x9.5 +18 Vision Raptor wheels wrapped in 37x12.5 Terra Grappler G2's
6.4L Hemi running on PP 0w-40 and Red Line 10w-40 blend (5+2)
PML tranny and rear diff covers, Red Line fluids
RAM_Designs is offline   Reply With Quote
Old 01-07-2017, 06:39 PM   #24 (permalink)
Ram Year: 2017 2500 Tradesman
Engine: 6.4L Hemi
Default
I know what your saying here is somewhat anecdotal, but I have to admit my gut feelings with a few hours of internet surfing kinda made me think along the same lines, hence why I started the thread in the first place.
My hunch is that the Castrol 0w40 made in Belgium and a true group 4 synthetic is a better bang for the buck, and easier to obtain than the PUP. I'll let you all know if I was right 10 years from and 120,000 miles later...
__________________
2017 Ram 2500 Tradesman 6.4L Hemi, Off Road Package, 4.10 anti-spin Dif, BW 44-47 T-case
HS-LD is offline   Reply With Quote
Old 01-07-2017, 09:38 PM   #25 (permalink)
Hootbro's Avatar
Ram Year: 2015 2500
Engine: Hemi 6.4
Default
Trying to get educated here but what in your opinion makes PUP 0W-40 a weak additive pack?
Also as you stated on the SRT forums, what exactly is making some go to another oil? Is there increased wear for them and if so, is there examples of this?
__________________
Hootbro is offline   Reply With Quote
Old 01-07-2017, 10:36 PM   #26 (permalink)
Ram Year: 2016
Engine: 6.4L Hemi
Default
I'm not sure about the details of the add pack myself, but I do remember that the oil shears down to a 30wt pretty easily, since it is already a very thin 40wt oil.
I don't like thin oil.
__________________
Old 01-07-2017, 10:44 PM   #27 (permalink)
Hootbro's Avatar
Ram Year: 2015 2500
Engine: Hemi 6.4
Default
Yeah, I got three oil analysis and aware of the shearing. That does not bother me. Nothing shows elevated wear because of it for me. If anything, it reinforces to me use of a good 5W-30 is not a issue.
Just wonder why the some of the SRT guys are moving away from it but I am sure they run their engines a bit harder especially if they track it.
__________________
Old 01-08-2017, 09:02 AM   #28 (permalink)
HvyDuty's Avatar
Ram Year: 2016
Engine: 6.4L
Default
I've been running Castrol 0w-40 since my first oil change. Immediately noticed more quiet cold start up. Tow a 30 ft 8k travel trailer regularly. No CEL, no issues.
Like has been said on here, my Hemi really woke up at around 10k miles.
I get my Castrol 0w-40 from Amazon shipped to my door for about the price of any other synthetic oil. IMO it is a steal.
__________________
2016 2500 6.4L Crew Cab 4x4 3.73
HvyDuty is offline   Reply With Quote
Old 01-08-2017, 12:27 PM   #29 (permalink)
SHOOT2KILL's Avatar
Ram Year: 2015...2500H.D.
Engine: 6.4
Default
Looking for opinions on mixing 0w30 with 0w40 PUP...I read in this thread that the 0w40 breaks down to a 0w30 very quickly in it's life...Or is anyone using straight 0w30 full syn, and what have been the results. Reason I ask...Found CLEARANCE PRICED 0w30 full syn @ Autozone for $2.00 a qt...I don't mind experimenting with my next oil change...5 qts 0w40...2 qts 0w30...What do you think.........
SHOOT2KILL is offline   Reply With Quote
Old 01-08-2017, 03:28 PM   #30 (permalink)
Hootbro's Avatar
Ram Year: 2015 2500
Engine: Hemi 6.4
Default
I would say either run with a full 0W-30 or 0W-40 fill than mix. While all API rated oils are mix compatible, you might not get the best benefit if of either depending on chemistry make up between the two weights.
Those that mix with any seriousness, do so staying with the same brand of oil between the two weights and not different brands.
Having run 5W-30 in my 6.4L, I would have no problem running a full 0W-30 if needed.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
