anybody running 36s with a levelin kit
bighorn2500
2015 2500 ram bighorn
6.4 hemi
Trying to decide on tires ready to buy just want big as i can go without rubbing fenders.
Broke pilot
Conroe, TX
6.4L
Depends on back spacing/offset. You can fit a 37/12.5 with the right wheels.
Wandell
Cummins 6.7
Yep. It seems everyone and there brother is running 35's with only a leveling kit. I've seen a few running 37's so I'm sure you can fit 36's. But a lot depends on wheel width and backspacing/offset. Also, how wide are the 36's you want?
bighorn2500
bighorn2500
6.4 hemi
Factory wheels is what id like to use
bighorn2500
bighorn2500
6.4 hemi
Will factory backspacing work.
Broke pilot
Conroe, TX
6.4L
Factory wheels will be your best bet. But if they're the 20" snowflake looking wheel, they're narrower than most plan on. Anything over a 12.5" tire is gonna be pretty pinched on it.
bighorn2500
bighorn2500
6.4 hemi
I have the 18s im thinkin about trail grapplers.
Broke pilot
Conroe, TX
6.4L
Not sure on the width of the 18's... Can't be any worse than the 20's. And you're in luck, they make a 37/12.5/18 in the trail grapps
bighorn2500
bighorn2500
6.4 hemi
Thx for the help
mtu1293
Upper Michigan
Could be doable, mine are 34.8" on aftermarket rims with no levelling kit. Have never really flexxed er out and maxxed the steering to one way, but those stupid plastic inner wheel wells have a bulge near the back the tires can rub on slightly.
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
mtu', if you could post a pic of your truck from the side I'd like to see your truck/wheel/tire combo and how they look. Thanks
mtu1293
Upper Michigan
Few olders ones - limited in choices of pics since I'm at work right now....
No rubbing with 2yards of fill dirt either :)
mtu1293
Upper Michigan
Ok I lied, got on photobucket and uploaded some old pics just now. This will help others when they search for either larger tires be it 35s and above. Trying to show how close they come to some of the fender inner wheel wells.
Straight on shot
Front of inner wheel well no issues, turned to full lock (not 100% if you had pressure on steering wheel).
Looking at front tire rear part of inner wheel well. Actually less chance of rubbing at full lock vs partial due to that stupid bulged out section. Could be more of an issue with wider tires I imagine as well.
More of a head on shot looking at tire turned to full lock without steering wheel pressure.
1Popeye
