SouthTexan
- Jan 24, 2015
- 2,149
- 1,303
- 2014
- 408 CTD
Will the place you are getting your 5er from let you borrow it or another the same size to see how well you truck does with the trailer? Like I said before, I believe your truck can handle that much weight with suspensions mods, but the only reason I would get a DRW for towing it often is stability. That is my personal preference you may be comfortable with the way your truck pulls it.
Looking at the specs of the Grand design 311bhs, it seems to be a little over 11k lbs dry and you will probably add another 2-2.5k when travelling which still puts you under its GVWR of just under 14k. You can put more of your gear in the back of the trailer when pulling it to lighten up the nose a little.
